Question about HP PL4260N 42 in. Plasma HDTV
PL4245N help with repair
I have the same T.V. and was wondering if you could describe the location or send a picture of the relay and resistor that you replaced. I have already replaced the power supply with no luck. Thank you, Andy
Please contact HP, they had extended their warranty for an addiotional year, they are aware this tv's are defective! Go to their website and see for your self:
Posted on Dec 28, 2008
1997 grand Cherokee lmtd
Had the same vehicle.. It's in the fuse box under the hood.. Take the cover off and look underneath the cover for the diagram..relay marked blower..
Nov 06, 2016 | Cars & Trucks
Blower moter will not shut off when I turn the key off.
More than likely it's the blower motor resistor. Gm's wonderful electrical engineers decided it was a good idea to run constant power to the high speed fan relay which is part of the resistor assembly. When the relay stick the fan stays on. The resistor is located under the dash on the passenger side ne'er the blower motor. There is a plastic trim pannel that will need to be removed from under the dash in order to see it. It is typically help in place with two screws that you will need a 5.5mm socket to remove (yes it's a 5.5mm socket). Lmk
Jan 31, 2012 | 2002 Chevrolet Silverado 1500
Where is the blower motor relay located under the dash
Not under the dash....
Sorry the picture is small but it is too large to post here.
Under rear seat fuse block
It is fuse 44.
Post your email address and I can send it in a bigger of charge of course.
Jan 23, 2011 | 2002 Chevrolet TrailBlazer
Fan does not work in position 1 2 3 works great in position 4
From the scenario that you have just described; more than likely your blower motor resistor pack has failed. On the highest setting, the blower motor will have no resistance from the resistor pack allowing the motor to turn the fan at full speed; however, on the lower speeds, the different resistors are what create your different speeds by varying resistance in the electrical circuit.
Jun 15, 2010 | 2001 GMC Sonoma Extended Cab
Blower motor will not blow fuse relay motor are ok
it could be that the motor itself is bad there is a relay inside the motor as well give these websites a try and if it was me i would checkout one at a good salvage yard give this website a try to find one close to you give this website a try wish you the best of luck Michigan Man.
Mar 13, 2010 | 1993 Buick LeSabre
95 volvo 850 blower problem
It is the resistor that is causing that.
It requires replacement, attempting to repair it is not advisable.
The resistor is bottom connector (h2) in the picture:
Sep 11, 2009 | 1996 Volvo 850
Blower for nissan titan
The picture I will try to attach will show you the blower motor housing. The white electrical harness rt hand upper corner is attached to the blower motor resistor. If you have checked the relay and its working ( you can check with a tester) the resistor is probably the problem. It's the most common a/c blower issue I see weekly hope I can send it and hope it helps.
Nov 07, 2008 | 2005 Nissan Titan
HP PL4260N 42 in. Plasma HDTV Logo
82 people viewed this question
Top HP Televison & Video Experts
Computer Links
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
