Question about Nokia N73 Cellular Phone
Instalation problem when i installed softweare and themes it show certificate not verified ans m as son as pos
Change d date n yr of ur mobile n thn install ...
Posted on Dec 11, 2008
Vx670 default certificate
hi dennis .. as far i know the default certificate is like an operating sys. for the terminal , u should send it to any verified centers for maintenance ..
Aug 11, 2014 | VeriFone new vx670 gprs wireless machine...
How can i put a themes in my nokia n95 8gb?
Hi
Before installing any software go to
Menu> App.Manager> Options> Settings> Software Installation
In Software Installation make it ALL. This change is important, otherwise you will get an Error message Certificate Error. Contact the application supplier while installing most freeware
Also, if you see that some old themes are giving the Expired Certificate error, simply change the date of your phone to year either 2005 or 2006 or 2007 (check all as each theme has a different expiry) before installing the theme. After installation you can change back to today's date.
Now, here is the way to install themes and other applications in your Nokia . I use the USB Cable to do the installations.
1. First install the Nokia PC Suite software on your computer from the CD which you recieved with your Nokia
2. After Nokia PC Suite is installed in your PC, connect the Nokia to the PC with the USB cable which was provided in the box.
3. When the USB cable is connected, Nokia PC Suite will recognise that a phone is connected. You will then see an option on your phone?s screen asking if you want to connect via PC Suite or Data Transfer. Choose PC Suite.
4. Now, simply download the .sis or .java files (themes & applications) to your computer and Right Click on it with your mouse. You will see an option saying Install With Nokia Application Installer
5. Click Yes on the PC, and then Yes & Continue on the Phone when you see the prompts.
6. The phone will then ask you if you want to Install the Theme or Application in the Phone Memory or Memory Card.
I strongly recommend Installing themes in the Phone Memory! This helps in avoiding complications later on when Uninstalling.
When I first bought the Nokia N95, I made a mistake which a lot of new S60 3rd Edition users make, that is, I installed the Themes in the Memory Card instead of the Phone Memory. This was a huge mistake!
There is a bug in the Operating System of all S60 3rd Edition phones, due to which, if the theme is installed in the Memory Card, it cannot be deleted or removed, as it then does not show up in the Application Manager.
Ever since that mistake, I have made sure to always install themes and softwares in the Phone Memory, instead of the memory card. Yes, it eats up space on the phone, but it's worth it, as then it is easily removed as well.
And that's it, the theme or application is now installed!
Thanks for using Fixya.
Mar 14, 2011 | Nokia N95 Cellular Phone
How to install .sis theme on nokia 5233, it gives me certification error
when receiving a certificate error on installing .sis file, try to set the date on your cellphone at an eralier time, say 01/01/2007..
Jan 31, 2011 | Nokia Cell Phones
How to save themes in my phone
Theme file like that is unsigned, which generally has a specific lifetime to be able installed on the phone. To fix this, change the phone date according to the date of theme still valid.
For example:
Open Menu > Settings > Find Date & Time. Set your Year to “2006′. Because some applications are certificated for 2005-2006. After setting your Year to 2006 install the application who gives certificate error. Finish your installation and you can set your current date back :)
Before it, make sure that you had check online certificate on the phone.
Go to "App. Mgr.", press "Options", press "Settings", make sure "Software installation" is set to "All", and "Online certif. check" is set to "Off".
May 27, 2010 | Nokia 6300 Cellular Phone
When i apply themes in my nokia 3110c it shows that unable to open theme corrupted
Those themes will be either from an unauthorised source or having an expired certificate.Please do not install such themes on your device as it will contain viruses which may be harmful to your phone.So remove it from your phone as soon as possible.The themes which are not supported by your phone will also show a corrupted message.
Jun 27, 2009 | Nokia Cell Phones
How can I insall Themes on E63 When I Install it. It shows Certificate Expired
Certificate expired is when the theme has expired, best thing to do is look at the date of the theme before you download it so you won't have this problem.
Try mobile9 website they show the expire dates
Good luck
Apr 23, 2009 | Cell Phones
When try to install theme, error coming 'Expired Certificate'
plz tell me the format of theme u use, maybe its damaged,
try true ones
eg. here is a theme link for ur phone(download it):
http://abul.mobile9.com:8080/download/content_delivery.php?key=NDI1L245Nl91bzk2bDNtNS5zaXN8MTI0MDIxOTQzOXw=
Apr 20, 2009 | Nokia E66 Smartphone
Certificate error contact application supplier error msg
Send me the theme File i can get it signed for u.or visit this link http://www.mobilesmania.com/forum/index.php?&showtopic=49264 u will get an idea on how to sign files.
Dec 16, 2008 | Nokia N78 Smartphone
I accidentally deleted the certificate
try to download themes fro your mobile from zedge.net or ownskin.com you can get all new themes try to install directly or through p.c via usb or bluetooth
Oct 04, 2008 | Nokia N81
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
