Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster 1265LM 1/2 HP does not open or close with remotes
The motor sounds but the door does not open or close using the remotes, it can be manually open and close while pressing the remote. Any suggestions?
  • Anonymous Mar 16, 2014
    liftmaster 2255 opener occasionaly opens or closes by itself
    Champion:
  • 244 Answers
Is chain moving. if not, gears are shot. if moving, is trolley connected.
Posted on Jan 15, 2009
My liftmaster 1265LM will not close with the remotes, but will close only if I hold the wall button. Please advise.
Sounds like a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
May 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
My door opens easily w the manual remote or the onboard remote in my car, but it does not close using either remote.
Guessing here, but sounds like it is one of the relays on the motor drive unit. Look for some relays where the antenna wire is sticking out from the motor unit. Likely one or two of them are bad
Feb 13, 2011 | liftmaster Garage Door 1/2 Hp
Product Lift Master Professional Line 1/2 HP Security + Model # 1265LM Door goes down intermittently. Door will go down approx. 8 - 10 inches, stop and then retract. Remote in hand, I press the...
Check alignment of the obstruction sensors .... they shoot a light beam across the doorway about 6 inches above the floor. One is mounted on each side of the door track near the floor.
Aug 29, 2017 | liftmaster Chamberlain Garage Door Opener...
Keypad 976lm won't learn if other remotes are already "learned". Will only learn if memory is cleared and then standard remotes won't learn. Unit is a 1265LM Liftmaster.
It sounds like that keypad did not come with the opener but was an earlier model. Make sure the keypad is one that is listed as compatible with the opener.
Sep 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Garage Door Won't Close
Sounds like maybe the door traveled too far and the trolley has jammed against the bolt just in front of the motor. If so, loosen the chain enough to take the tension off the chain and then run the opener until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit and turn it 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
May 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster 2265 1/2 hp remote does not close
If the door starts to close and the main light flashes 10 times and the door reverses to the open position it is a problem with the door sensors. Make sure they are pointed at one another and they each have a small light that must be on and not flickering.
If it starts to close but reverses and the main light does not flash 10 times it is possibly the RPM sensor which is a small printed circuit board just in front of the motor.
Nov 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
LIftmaster light flickers but won't open garage door
check your wire connections at the opener one of the little wires probably broke
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not open
Sounds like you might have a broke spring. Put the door all the way down and release the manual release. Now try to lift the door. If the door is heavy you might have to call a door company in your area to add tension to your springs or if they are broken both springs should be replaced.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,446 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
