Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Error code A10 for hotpoint FDW70G
This error code has appeared so my dishwasher will not work.
  • 157 Answers
Posted on Dec 19, 2008
A10 code Indesit Dishwasher DSG573
A10 is a heater fault check heater or look for poor connection on module normally the pink or blue wire
Jan 24, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Error code A8 appears on my hotpoint Dishwasher
On my sheet of error codes i dont see a A8 for Ge/Hotpoint dishwasher(ge makes the hotpoint brand) i do see a C8 which i assume is the same thing and that says the detergent cup was blocked and couldn't properly open
Aug 13, 2011 | Dishwashers
Fdd914 dishwasher error code A10 appears and its not in the booklet
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
My aquarius hot point fdw70 comes up with error a10
Check out for all hotpoint error codes and what they mean
Oct 07, 2008 | Dishwashers
Hotpoint a10 error message
Dishwasher starts water runs ok then stops and flashes A10 ???
what does this mean,, Ian .
Jun 29, 2008 | Hotpoint Dishwashers
FDw70G Hotpoint salt light wont go out
I have exactly the same problem with my FDW60 model! I have email hotpoint to ask them whats the matter with it, so if/when i get an answer i will let you know!
Feb 05, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW80( A10 Appears ondisplay half way through cycle)
here are the fault codes for your machine...
Fault codes for LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water
  • Hope this helps?
    Jan 06, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    I have a Hotpoint FDW70 dishwasher
    Disconect POWER at breaker or fuse panel which should be on a seperate braker. if not find the power sorce and unplug the device. FOR SAFTEY Kneel on a thick doormat if you have to disconect power which has a plug. Wait for a an hour so to let all circuits, timers and motors to cool ... with diswasher in the OFF position, Re-establish POWER. then go ahead and start washer as sugessted by the Manufacturer. Make sure to notice any other codes that may appear. Or any peculiar noises. Most default codes appear if water pressure is too low. Top loaders are natorious for plugged drain lines and can be flushed by the home-ownwr. Make sure to check that water strainer is not cloged or restricted. Hotpoints CODES change from year to year, You can contact a Hotpoint Dealer in your area ... Give him the Make, Model, and any Series numbers to him. MOST will tell you what the CODES ARE FOR THAT MODEL OR EVEN E-MAIL ALL OF THEM TO YOU. Good Luck ... Be Safe Joe Rex
    Oct 09, 2007 | Hotpoint 24 in. FDW60 Free-standing...
    Hotpoint Aquarius+ FDW70 Error Codes
    i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
    May 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
    Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
    448 people viewed this question
    Top Hotpoint Dishwashers Experts
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
