Black line When scanning I get a large black line about 1/4 down the screen
  • 492 Answers
Scanner needs to be cleaned with lens cleaner. Also try unistalling it and reinstalling it.
Posted on Dec 10, 2008
How do you fix samsung ps50a457p1dxxu has black verticle line down centre of screen
A vertical line could indicate a faulty lower scan (long skinny boards along the bottom of the set) board, a faulty lower scan connection to the screen or a bad screen altogether!
Jun 08, 2014 | Samsung Televison & Video
EPSON WORKFORCE 840 AUTO FEED COPIES HAVE BLACK LINE DOWN THE SIDE
This was my exact problem. When scanning from the ADF, I had a vertical black line down every page. I cleaned the larger glass surface several times with no effect. Then, I discovered that ADF scans do NOT use the large glass area, but use the smaller, thinner glass area on the left side. It has a piece of thin plastic over the top of the glass. The scanner is fixed and the paper rolls through this area. So, if a speck of dirt is under the thin plastic piece or on top of the glass or on top of the thin plastic, it results in a black line down the whole page. Aha, so now I cleaned the thin plastic (both sides) and the top of the glass under the thin plastic - actually saw the black dot that was causing the problem and voila, problem solved.
Jan 30, 2012 | Epson Office Equipment & Supplies
LARGE HORIZONTAL BLACK LINE- PSC 1610 PRINTER COPIES
NO, I DID NOT GET IT FIXED. YOU TOLD ME TO SCAN SOMETHING TO THE PC, WHICH I DID. SENT PAGE TO MICROSOFT WORD AND THE BLACK LINE WAS STILL THERE. I BELIEVE MY SOLUTION IS TO JUNK THIS THING AND BUY ANOTHER.
Jan 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Large Black streak on outbound fax/copy
1 or 2 LEDs are burned out in the scanner unit.
Sep 23, 2009 | Brother IntelliFAX 4100 Laser Fax
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Black vertical lines in copies
You need to clean the glass. Open up the feeder and you have a large piece of glass for scanning and to the left a smaller piece of glass that it uses to scan from the feeder. Clean this smaller piece of glass; even the slightest smudge can leave a black streak.
Jun 25, 2009 | HP LaserJet 3030 All-In-One Printer
Screen has black line down the middle.
it sounds like a setting in the progressive scan or screen ratio menu.
May 04, 2009 | Video Game Consoles & Games
Black Line when scanning or copying
This appears to be a scan head problem either not completeing a full travel or a ccd problem Could even be a piece of some thing come adrift and masking the ccd- can you see anything like that. What ever it is it wont be a repair[unless you can fix it your self] Replacement is only answer I think
Aug 27, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
88 people viewed this question
jasbo
jasbo
