Wega Mininova EPU Espresso Machine
Problem for Wega Mininova EPU Espresso Machine
Where can I buy the seals for the inside of the coffee maker. I fabracated one but it doesn't do ....
By Rogers - usenet poster
Where can I buy the seals for the inside of the coffee maker. I fabracated one but it doesn't do the job. Everywhere I have looked tells me that they don't sell these things because it takes a factory trained repair person. help?
Same Problem
Aug 30, 2008
-   I turned the seal ring over to use the undamaged side.
The seal ring material is soft and has enlarged beyond the original size.
It now does not fit properly and allows the steam to leak.
-   Guest
Aug 27, 2008
-   Hi I have a Gaggia coffe deluxe machine and also I have ordered from Gaggia UK an brewhead rubber seal but I am unsure how to remove the old rubber seal and replace it with the new seal.
Russ MK. UK-   russellp
Aug 01, 2008
-   I am trying to find a Coffee Tank Filter Screen for Model No.47535 HamiltonBeach Brew Station without the timer Type A44 Coffee Maker-   Marie2145
Jul 11, 2008
-   where to find seals for inside lid of coffee maker
-   Guest
Jun 11, 2008
-   I just bought the new seals for my la pavoni europiccola (new group) but i can't fit the group seal in the brew head!! any tips?? i'm getting really nervous guys!-   simonegueri
Best Solution
posted on Jun 02, 2008
Very Helpful)
wrencher
Rank: Wiz
Rating: 81%, 48 votes
seals and stuff can be gotten here
www.mar-beck.com/coffee_filters_parts_bunn.html
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 24, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I just bought replacement gaskets for my stovetop from EspressoZone.com
Solution #3
posted on Apr 07, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution #4
posted on Jul 27, 2007
Helpful)
Diana J
Rank: Apprentice
Rating: 92%, 11 votes
I had the same problem and called Hamilton Beach customer service (1-877-474-1122) I had all intensions on purchasing a new seal but to my surprise they said that they would send me a couple as a courtesy. I hope that this helps.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #5
posted on Aug 08, 2005
Somewhat Helpful)
Gary10
Rank: Apprentice
Rating: 0%, 0 votes
Have you tried to obtain the needed parts from the local small appliances parts stores or the local fix-it shops - Most every town has fix-it shops where small appliances are repaired. These stores also sell parts. Inquiring may be worth a try.
Try calling the manufacturers customer service center. Check the manufacturers web site. Also appliance parts stores. These stores are all listed in the local phone books.
In my opinion and I could be wrong, you are being told "it takes a factory trained repair person" because those saying so want you to allow them to fix it for a price.
Which makes sense, if they are in the business of fixing small appliances. About the only cautions needed are dealing with the electrical connections and componets.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions, test and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Was this helpful?
Yes
No
Solution #6
posted on Dec 08, 2008
Not Rated)
brentcolby
Rank: Apprentice
Rating: 0%, 0 votes
Call DeLonghi at 800-322-3848.
I ordered two new seals and had them shipped for $18.42
I looked everywhere for this answer and could not find it anywhere... wanted to let you all know!
Good luck and good brew!
-Brent
brentcolby@gmail.com
Was this helpful?
Yes
No
Solution #7
posted on Sep 08, 2008
Not Rated)
redgreen08
Rank: Apprentice
Rating: 100%, 1 votes
Was this helpful?
Yes
No
Solution #8
posted on Aug 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
By Mail: The Krups Online Store
20 Constitution Blvd. South
Shelton CT 06484
By Phone: Contact Center Hours:
Monday – Friday 8am – 8pm EST
1-800-387-3995
http://www.krupsonlinestore.com/product_list.asp?SKW=PARTXP2010&SEARCH=&MENU=parts&SELECT=espressomachines&PGN=2
Solution #9
posted on Jul 15, 2008
Not Rated)
marfu93
Rank: Apprentice
Rating: 0%, 0 votes
Was this helpful?
Yes
No
Solution #10
posted on Jul 06, 2008
Not Rated)
roythomas100
Rank: Apprentice
Rating: 0%, 0 votes
Appliance is obviously not 'fit for purpose' and therefore, under consumer law, the retailer (not the manufacturer) must refund or replace as you have a contract with them as suppliers. As an appliance engineer of 36 yrs standing I've often met this problem with retailers trying to shift responsibility onto the manufacturer. If no result involve your local Trading Standards Office.
Was this helpful?
Yes
No
Solution #11
posted on May 12, 2008
Not Rated)
SEGABMET
Rank: Apprentice
Rating: 0%, 0 votes
Where can I get a thermal fuse for my Krups KP1010? Mine has opened and I can't get hot water out of it.
Was this helpful?
Yes
No
Solution #12
posted on May 10, 2008
Not Rated)
theblakelys2
Rank: Apprentice
Rating: 0%, 0 votes
You can order seals for $3.99 + shipping and replacement tanks at
http://abtecparts.com/hamilton_beach_coffee_maker.htm
Was this helpful?
Yes
No
Solution #13
posted on May 05, 2008
Not Rated)
babbittman
Rank: Apprentice
Rating: 0%, 0 votes
where can I buy the ion-exchange water filter for my KitchenAid coffee maker model 4KCM514
Was this helpful?
Yes
No
Solution #14
posted on Apr 27, 2008
Not Rated)
smancuso
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with the nespresso krups xn20 machine. After calling the Nespresso service desk they substituted free of charge the water tank, which has a little valve with seal at the bottom. It turned out that the problem was not the seal of the water tank, but the seal of the machine (onto which the water tank is installed).
I solved the problem by using Teflon tape (same type as that used to connect for water pipes) on the water tank, applying it at the appendix which goes into the machine.
It's been working ok since then (couple of days). The only problem could be the wearing-off of the tape after some time (you will have to reapply it).
Was this helpful?
Yes
No
Solution #15
posted on Mar 24, 2008
Not Rated)
steiny phil
Rank: Apprentice
Rating: 0%, 0 votes
Greeting's. Where can i find spare parts for the KOALA Espresso
coffee maker ? The top of the Boiler casing appears to have a very
fine crack in it an 2 of the Screws around the top of the Boiler are
missing ( fell out ??? ).
cheers from Phillip.
Was this helpful?
Yes
No
Solution #16
posted on Feb 16, 2008
Not Rated)
Badlybent
Rank: Apprentice
Rating: 0%, 0 votes
DC Coffee products has a full line of repair parts in Illinois. I've delt with these folks and found them to be extremely helpful.
Was this helpful?
Yes
No
Solution #17
posted on Dec 30, 2007
Not Rated)
Jacco
Rank: Guide
Rating: 87%, 7 votes
For Gaggia Classic, Parts Guru, espressoparts and Whole latta Love on the web have various parts for that type of machine. Google Gaggia parts will help or use Espressotop50.com
Was this helpful?
Yes
No
Solution #18
posted on Nov 16, 2007
Not Rated)
JohnnyBeans
Rank: Guru
Rating: 85%, 90 votes
Was this helpful?
Yes
No
Solution #19
posted on Oct 25, 2007
Not Rated)
hankswanky
Rank: Apprentice
Rating: 0%, 0 votes
the same seals used for blenders will work
Was this helpful?
Yes
No
Solution #20
posted on Oct 16, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution #21
posted on Sep 01, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
All parts lists and diagrams are available at the Bosch website for this coffeemaker. Use part number tka 9110 uc. Takes some looking to find it. The seals are available for around $2.00
Solution #22
posted on Jun 20, 2007
Not Rated)
skull
Rank: Apprentice
Rating: 92%, 7 votes
The parts are available, ask your local Krups distributor for contact details for a service agent, they will be able to help you.
Was this helpful?
Yes
No
Solution #23
posted on Jun 15, 2007
Not Rated)
ucfben
Rank: Apprentice
Rating: 0%, 0 votes
Martin Coffee Company in Jacksonville, Florida has all the Bunn Parts you will need. (866) 355-9661.
Was this helpful?
Yes
No
Solution #24
posted on Mar 28, 2007
Not Rated)
virgy
Rank: Apprentice
Rating: 0%, 0 votes
if you are in brisbane australia, i suggest Sparkys Small Appliances at Albion on 0732627129. They are authorised service agents for this product and also sell the parts. I found that if they did not have the part, they will order it for you. They even post anywhere in Australia. They gave great customer service. They even have the genuine descaler for the Eam3200.
Was this helpful?
Yes
No
Popular Solutions for Wega Mininova EPU Espresso
Questions and Unsolved Problems for Wega Mininova EPU Espresso
Do you recommend Wega Mininova EPU Espresso Machine?
Answer
Answer
how do I hook up reservior? No longer have it plumbed into wall.
Answer
Hi, I have a older black and decker spacemaker coffee maker odc150 and I need parts black and decker... (More)
Answer
is there a video that shows how to install a black and decker spacemaker coffee pot
Answer
what I will install in www.mininova.org if other downloads are have a problem...
Answer
It's less than a year old and will turn off cup by cup of brew.
21 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 06, 2008
I have a problem with the rubber ring in the lid of the carafe. It comes off and then is virtually impossible to put it back on the way it came from the factory. Also, this makes it difficult to pour the coffee out. Any suggestions would be appreciated.
Comment by Guest, posted on Apr 27, 2008
je souhaite la vue éclatée de la fiche technique pour la granos 3020.
Elle n'a plus de garantie et je vousdrai la réparer moi même.
C'est la 3 em et toujours le même problème.
Merci de votre réponse
Françoise
mon mail : francoise.gandoulas@orange.fr
Comment by Guest, posted on Apr 17, 2008
I just purchased the cook's essentials mill & drip coffeemaker with thermal carafe. When you pour the coffee into your cup it leaks all over the counter. When you put the carafe back on the coffeemaker it leaks profusely out of the handle. I would belive that a seal is missing from the carafe lid allowing the hot coffee to seep into the trim ring then into the handle. This is a brand new appliance. Doesn't the manufacturer test these coffeemakers before selling them?? I need to rectify this problem soon. This specific style is the same as a Melitta coffeemaker that I owned a few years ago and I loved it. I don't love this one.
Jo Ann
Erie, PA
Comment by Guest, posted on Mar 17, 2008
We have the same problem with our Barista Coffee pot. We have to stay by the pot when making coffee to avoid water or coffee all over the counter top. We probably need to replace a seal in the lid. Where or how can we find this part?
Comment by Guest, posted on Feb 16, 2008
seal is deterated at top where water go into tank, lookes like a hard gasket, pot is about 7 years old. bun coffee pot
Comment by waterking, posted on Feb 07, 2008
i need to purchase inside of the glass from bodum.
can you halp me where can i purchase.
Comment by Guest, posted on Jan 30, 2008
I do have the tracanzan 2 kops maker. alfa italie and the same problem, where can i find the rubber seal?
Comment by mawick, posted on Jan 20, 2008
The rubber ring that fits around the bottom part of the lid that screws into the carafe is missing. I cannot find where I can have it replaced. Any ideas?
Comment by Guest, posted on Jan 19, 2008
I have the same problem. The rubber ring has perished/melted, so they unit doesn't build pressure, and no one seems to be able to sell me a replacement ring. Although the unit is two years old, we have used it less than a dozen times and it looks brand new. Can't say I'd recommend this product.
Comment by Guest, posted on Jan 01, 2008
Try here: http://www.lacafetiere.com/Consumer/Products/Consumer_Bialetti.asp
they are the UK distributer and stock all parts.
Best of luck!
John
Comment by Guest, posted on Dec 19, 2007
Bunn home coffee maker, leaks water underneath the unit. It apparently needs a new seal. How to replace and where to buy. The unit is seven or eight years old.
Comment by jpryde, posted on Dec 18, 2007
Removed all the screws. How do you get the darn thing apart???
Comment by Guest, posted on Nov 21, 2007
Can not get spiket to open to get the coffee out of the pot. What do I need or order to get this pot to work.
Comment by Guest, posted on Nov 20, 2007
I unscrewed the steel sieve like plate to find a tear in the rubber gasket that seals it to keep the water pressurised. I haven't been able to find a spare part for my Krups online anywhere yet??
Thanks
Jesse
jesse.locke@didata.com.au
Comment by bjean, posted on Nov 04, 2007
I have the Tracanzan Alfa Blue 4 cup and need a new seal. Whole Foods does carry some seals but they look too thick. Before go buy&try I decided to try the internet. Any help would be greating appreciated.
Comment by CWHonkahi, posted on Nov 02, 2007
I need to find a top filler tray/funnel for a GR. The tank filler hole has become brittle from the heat of the tank and has broken away around the seal.
On the bottom of of the tray/funnel is a number 4852-A.
Looked all over the Web to find only customer replacement parts. Where can a tecie get the right parts?
I guess I'll call the 1-800 number in the morning.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Wega Mininova EPU Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
