Question about Samsung LN-R328W 32 in. HD-Ready LCD Television
Samsung LN-R328W HDMI Picture Size
I have a 32" Samsung LCD-TV. exchanged digital cable box for HD box. The picture for both HD channels and Digital channels is not full screen. how can II get full screen for both HD and Digital channelsInput is HDMI :HD STD. The picture is never full sized in Wide or Zoom mode. Panorama is not available for HDMI or HDTV. I must operate in Wide to get the full vertical picture but the picture never fills out the screen horizontally. Please let me know if there is a solution to this.
  • 492 Answers
Depends on your box. But typically you can call your cable company and they will assist you in setting the box to force the signal to streach to the screen.
Posted on Dec 10, 2008
Hi My LG 52LB9DF tv is slightly blurry - I'm not sure if it's the size or quality of the tv? Even the HD channels are slightly pixellated. My friend has a smaller tv with a much sharper resolution....
1. Your TV has a digital tuner built-in, you do not need a set-top box to receive local digital channels.
2. Try to disconnect the box, hook up the antenna directly to the TV antenna input & program the tuner, you may getting better picture.
Aug 29, 2017 | LG 52LB9DF LCD TV
Ghosting problems with a Samsung-LN32B360
I think your cable box is old version together with weak signal caused this problem. I guess you are using coaxial cable hooked up to the TV at TV cable input jack.
At the TV there are some better quality inputs which are real digital transmission (audio and video) HDMI and components (digital video and analog audio).
The most simple and best quality is HDMI provided the box has HDMI output.
Secondly is component inputs. There are 5 cable trends in which 3 of them (red, blue, green) for video and the rest 2 are for audio (red , white). The cable box should have same color accordingly as ouput. Please note that the color must be matched otherwise you will see the screen has one color only.
Playing a DVD player to see picture good or not. If picture is good, TV has no problem at all.
May 25, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Color problem
hi it could be a loose cable in the back of the tv
Jan 10, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Loose HDMI Connection
Dont use the HDMI connection OR replace the main board. Its directly soldered to the main board. The back should come off IF you have removed ALL the screws and the little screws things that hold on the VGA connections etc. There are also some obscure screws holdin the back on.
Jul 02, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Picture Size problem with Samsung Flat panel LN-T3253H
You should contact Samsung service to know if the internal setup for the picture sizing was not adjusted properly at the factory.
Take care that some of these sets have a user zoom mode. Maybe it is in the zoom mode. Check in your instruction manual before calling for service support.
Jerry G.
Apr 12, 2008 | Samsung LN-T3253H 32 in. LCD Television
Gray borders on the HD channels
Have you tried to change the screen size? To do that press the "Psize" button on the remote till you find what you need.
Dec 29, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
TV Sound
First lets determine where the sound is missing. What are you using for sound. RCA jacks? HDMI cable? If you are using the HDMI cable, please make sure the correct sound is selected in the Cable box. In New York Cable Box, The HDMI sound has to be selected in order to get sound using the HDMI cable. Hoping that all other settings are ok, You may need a new signal board. Part Number BN94-00629R. Average Cost $176.14
Best regards
CircuitCity
Nov 22, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
105 people viewed this question
Henry  Thomas
Henry Thomas
