Question about Dayton E50 Heater
Blower fan humms won't spin - Dayton E50 Heater
  • jeeporvis97 Dec 13, 2008
    I have the same problem, not sure what it is though, it doesn't even fire up, it just clicks, and then humms.
In my case, the bearing somehow wore away a grove on the pump side of the shaft in the motor causing the motor to be "sucked" to the magnets and not turn. I'm having the shaft turned down and a new sleeve put on. It should work, we'll see what happens.
Posted on Dec 17, 2008
A/C is cold but blower not working when I turn on I replaced blower
You may have a bad capacitor. Does it humm or vibrate very low?
May 10, 2016 | 1996 Isuzu Rodeo
Drum wont turn just humms
Open the door and check of the Tub spins freely, if so then you have a bad motor and if it does not you could have an object stuck in the blower wheel which is attached to the motor and prevents it from spinning
Jan 22, 2016 | Dryers
Goodman clt60-1 fan not working loud humm
The hum is a good indication that the fan is getting power. Therefor, the fan is locked up or it has a weak capacitor. Attempt to spin while power is off. It should spin freely. if not, you will need to replace the motor. If it spins freely, I would attempt to spin the fan blade while it is humming. If it starts running fine, it is very likely the capacitor. If not, then replace the motor.
Sep 08, 2014 | Goodman Heating & Cooling
Blower won't run
usually a "humming motor" indicates either a bad capacitor or a defective motor. With the power off try to spin the blower should spin freely. If it is tight or wont spin and there are no obstructions stopping it (like an air filter sucked into blower or other debris) then the motor most likely is seized. If the blower wheel spins free then you may have a bad capacitor. Keep in mind, just because the blower spins easy doesn't mean the motor is good. I have had motors that are defective that dont seize up but most of the time the blower wheel will not spin free if the motor fails.
Oct 07, 2012 | Desa International Blower Glow Warm Wall...
2006 gmc sierra fan wont work replaced blower resistor still won't work
Check for voltage on the fan itself- if the voltage is there then the fan motor could have cause the resistors to overheat due to it's drawing too much current. Oil the bearings with Tri Flow oil and they will spin much better- the trouble is you need to get the fan out to service it.
You can oil and recondition the Commutator and renew the fan if the brushes are not worn out if you have it on the bench.
Oct 01, 2012 | 2006 GMC Sierra 1500 2WD
Almost no air comes from the ac vents but fan is on high. This happens on auto and also on econ.
The 1992 was prior to Buick putting cabin air filters in so there is not a possibility it is clogged. So more than likely your blower motor is going bad or your fan control switch is bad. Does this problem occur with heating as well as AC? Does it change if you switch between blowing on floor, face, window(defrost) If it doesnt change based on location of blow and type of air temp then I would start by turning fan on high and placing head (ear ) against dash in center of console area. Have someone turn fan knob from low to high with engine OFF...After goign from low to high and back a few times you can see if the blower motor is responding to signal from switch. Listen for a whine, squeal, rattle, or humm. A whine or Humm would indicate a bad blower motor... Squeal or rattle a bad squirrel cage/fan blower blades. If you hear no noise and no perceivable change in blower speed/noise then its possible your switch is bad. Unfortunately the only way to definitely diagnose either is to pull the switch from dash and use multimeter to test for voltage change and for blower motor to pull dash. There is a digital control unit for your car as well. Although rare sometimes the wires on this can loosen or it can go bad. But since you didnt state teh fan wasnt working at all and you are getting cool air, that woudl be teh last thing to check
Jun 06, 2010 | 1992 Buick Park Avenue
On my indoor unit the fan just humms will not spin while energize
Did you change the capacitor on the fan motor. Could be bad if not bad fan motor. But sounds like a cap. Russ
Jul 19, 2009 | Heating & Cooling
Blower fan is not coming on
I recommend you getting service its a safety thing. the humming is the transformer and is normal.. good luck Tom
Jun 22, 2009 | Ruud UBHC Air Conditioner
Amana Dryer
sounds like a bad motor or something stuck in blower fan.. see if you can maually turn the drier drum if so motor is bad if not something is binding up drum or blower fan.
Nov 03, 2007 | Amana DLE330RAW Electric Dryer
Dayton E50 Heater Logo
103 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
