Question about SimpleTech SimpleDrive 250GB, 7200RPM, External, USB 2.0 (COMPUSB235250) Hard Drive
Not being recognized by computer
I have a Simpledrive 320 G drive. It shows as an external memory but does not show under my computer. I tried three different machines and different USB cables but no answer. Any ideas?
  • 1,006 Answers
Is that external???If yess just buy new external...
Posted on Dec 10, 2008
How to get the software that came with my simpletech simple drive startup disc came with
That software is just there to put up an icon and name of the drive etc it is not important Your drive shows up in in Windows Explorer as a new drive letter If it is not showing you may need to download a mass storage driver.
Nov 20, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
Seagate 9sd2a3-500 320 GB Problem
Improve the Fixya experience for everyone by voting!
It sounds as though you have one of the following problems:
  1. Dirty contacts that can be cleaned with CRC electronic component cleaner;
  2. A faulty drive that may have been dropped at some point in time. Your drive may have a three-year warranty and Seagate will replace it. Just go online and provide the serial number; and.
  3. You may have to reinstall the drivers. The Seagate website can provide this if needed.
Apr 14, 2012 | Seagate 320GB Portable External Drive ...
My windows XP OS won't recognize my SimpleTech SimpleDrive Pininfarina 300GB External USB 2.0 Hard Drive
I found that often, external hard drives just don't have any active partitions and thus don't show up in Windows. Go into the control panel, administrative tools, computer management and then the disk manager and see if it has a partition. If it's just unallocated space, right click and make one.
Jan 16, 2012 | SimpleTech Simpledrive Computers &...
My computers no longer recognize my external hard
Check to see if its still under warranty. Most times they have at least 1 to 2 years. If it isn't, I would remove the drive from the case and slave it to your system to see if will work that way. Doing that will narrow it down if its a drive issue or a USB issue. Good Luck.
Apr 28, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Black
Try to go through disk management and see if it works?
Open control panel then select administrative tools then disk management. Then in left column click disk management.
If you locate it may be it must be initialise by the system or need to create partition by formatting.
You can also check all the cables , the power cables the adapter , try to change the Usb cable also..
ok
Good luck !!
Jan 22, 2010 | SimpleTech 320GB SimpleDrive External by...
I have a 320 g simpledrive and it was working properly, but not its not being detected by windows vista.
Try going to control panel-Administrative tools-computer Management then disk management. If it show there set ti active /primary
Aug 01, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech 250GB STORAGE S
try plugging your HD into another desktop/laptop to see if your HD is functioning well on a different computer. Could be the USB cable problem.
Feb 01, 2009 | SimpleTech SimpleDrive 160 GB External USB...
My simpletech signature driver 320 is not recognized by my PC
I had the same type of problem and found when I took the cover off that the harddrive worked loose from the plug. Pushed back into socket and reassembled, works great.
Dec 29, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech 320 gb
It has to do with the way computers count. Computers count in binary where we count in decimal.
Hard drive makers list there drives capacities in the decimal format, where windows lists it in it's binary format.
Wikipedia has a good explanation.
Also, the drive may have some preinstalled software on it that could be taking up a bit of space (it's usually not much).
May 15, 2008 | SimpleTech 320GB SimpleDrive External by...
SimpleTech 320 gb. Code 10 Problem
i doubt you can do anything about it. Code 10 is a hardware failure, so you will have to return it and get your warrenty.
Apr 28, 2008 | SimpleTech 320GB SimpleDrive External by...
Computers & Internet Logo
281 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
