Question about HP DesignJet 1055cm InkJet Printer
The HP Designjet 1055cm has 4 ink cartridges, 4 printheads and 4 printhead cleaners. My question is: Will the plotter still work properly if I just install the black ink cartridge along with the printhead and printhead cleaner?
  • Anonymous Mar 25, 2014
    black ink does not orint
  • 628 Answers
I doubt it. When the printer powers up, it checks to make sure that all modules are in place and functional. If one is missing, you'll get an error message.
Posted on Dec 10, 2008
I have a Designjet 5500ps Printer and it is leaking blue ink, when printing, all my research indicates that I need to replace the carriage tube connector, but I am unable to find the replacement part.
Hi there
May be you can try to contact any Authorised HP Service centre for your probelm. Could you give me your correct location so i can tell you whome to contact?
Alternatively you can try to see where the leakage is taking place and try to seal it with silicon sealent so it can atleast last untill someone attends to the probelm from HP.
The technical term for it is INK TUBE ASSY. But make sure and tell the HP people about the size of the plotter that is 42" or 60" and also keep the Product Number and Sl. No. of the machine handy which is required by HP technical team. (You can find it at the back of the plotter)
Click here to find all the spares for your plotter.
Aug 24, 2011 | HP DesignJet 5500PS InkJet Printer
HP designjet 1055cm plus: Installed new toner, printheads and printhead cleaner packs and the black one is failing? Said, alignment so reinstalled. Still failing. Help!
hello,
Try to reconfigure your printer setting and then run diagnostic on your printer to know the status of your printer if it still supports the new toner , printer heads you install.
Thanks
Jul 31, 2009 | HP DesignJet 1050c InkJet Printer
I replace the black ink printhead and cleaner for hp designjet 1050c and it keeps telling to reseat the printhead.
This message comes when print head is not fitted or locked properly in the socket, please remove printhead, also check for polythene conver on nozzle that should be also removed.
Dec 29, 2010 | HP DesignJet 1050c InkJet Printer
Hi Folks: I would appreciate any help and suggestions: HP DesignJet 1055CM error 0A0020 006501D1 Thanks, Paul
"Error in calibrating the APS sensor"
APS= Air Pressure System - it provides air pressure to pump in to the ink cartridges, thus pumping ink to the printheads through the ink tubes.
First things to try
- Remove all Ink cartridges.
- Power down printer.
- Power on.
- Place cartridges in ink supply station, check if they are recognized.
- Replace the one cartridge that is almost empty.
- Check all cables and air tubes in the ink supply station. (you need to remove left cover of printer)
Make sure they are all properly connected and not damaged.
Make sure the air tubes are free running - NOT pinched or bent!
- Lastly,
When all above fails, replace faulty APS sensor and / or pressure valve.
Oct 30, 2010 | Computers & Internet
HP Designjet 4000ps printhead error
Plz Sir
Stape :: 1
Your Printer Cover Open Few Minitus
Stape :: 2
Plz Chek Your Printer Property .... And Delete Your Own Page
Stape :: 3 Plz Check Printer Property And Port Tab Chenge Selected Port
Enjoy
Aug 17, 2009 | HP DesignJet 1055cm InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
HP Designjet 500ps 24" Plotter- screen says to replace printheads
Printheads are available everywhere, you replace them your self. Machine will usually indicate just one bad print head at a time.
Dec 22, 2008 | HP DesignJet 500ps InkJet Printer
THE SCREEN OF MY HP DESIGNJET 500 DOESNT WORK
I would suggest taking out all the consumables. Printheads, media and cartridges. Unplug for upwards of 20 seconds before plugging it back in but leaving the consumables out.
Try turning on the plotter. If it appears working properly, load all consumables one by one, cartridges first, then printheads, then media. Attempt to print a test page if it works.
Or try a different outlet. Maybe the one your using has a problem and doesnt produce enough electricity.
Nov 26, 2008 | HP DesignJet 500ps InkJet Printer
My plotter does not recognize always that a printer cartridge is seated and will print without cyan
A model # would help. HP makes cleaning kits for the majority of DesignJet plotters that includes a tool to clean the contacts in the carriage that holds the printheads. Other than that, you could try a chamois swab (I think you can still get them at Radio Shack) dipped in 91% isopropyl alcohol (shake of the excess) and try cleaning the contacts that the printhead comes in contact with. Oxidation and/or ink can cause a bad connection that gives you the no printhead error. Reply with the DJ model # & I will be happy to get you the cleaning kit part #. Here is link for to the cleaning kit for the DJ 330, 350C, 430, 450, 455CA and 700.
http://www.hp-bazaar.com/cartridge.php?product=HP-C6247A&type=HEW Hope that helps you...
May 30, 2008 | HP Office Equipment & Supplies
Open Questions:
See all HP DesignJet 1055cm InkJet Printer Questions
HP DesignJet 1055cm InkJet Printer Logo
447 people viewed this question
Ben Johnson
