Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Intermittent sound problem on sony trinitron
Got my TV back from repair shop (they fixed a power supply problem), but now there is a no sound however it occasionally comes on when the set is switched off, then on.model is sony trinitron.kv-32ws2b
  • 71 Answers
Take it back to repair shop/ bad fault not looking good
Posted on Dec 10, 2008
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
I have a Sony Trinitron KV-32HS500 - when you turn it off it goes into a standby mode and will not come back on unless you unplug it for about 5 hours. Then you can turn it on and it will work perfectly...
When fails to turn on: if you get a front LED blink of 4, 6, or 7 x, then pause, then likely power supply IC is intermittent with temperature. A lot of shops will want to replace the whole board for hundreds more, though. So ask a shop if they can fix this problem to component level 1st recommended.
Apr 18, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
When I switch on my Sony Trinitron Tv , it won't turn ON , only the red LED flashing in front next to start button , and sounds tik tik. Please advice .
take your tv to a repairing shop and let your technician check the power supply section is not producing an ht to trigger the line transformer, in turn various voltages will be produced, which will open up your tv.
Feb 26, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Kv-32xbr45 the power to house cut off and came back on now tv wont turn on, can it be fixed?
You may have had a slight voltage spike either just before losing power (posible lightning strike?) or after power was restored. May be as simple as a blown fuse. If you can check yourself it should be located in the incoming power line; if you can take it to a repair shop most can find and fix cheaper than a new TV but will charge a diagnosis fee of about $50.00 to $75.00.
Nov 27, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Tv will not turn on.
Check power supply, you might have a bad fuse, capcitor or resister that went out in this TV I would seek a local tv repair shop to rule out these issue outlayed here.
Sep 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV 27FS16 TV does not power on
The chirping is the power supply trying to start. This is not a repair that I would recommend a novice attempt. PLease have this unti serviced. Expect a parts cost in the $20-$40 range for power supply caps.
Dan
Aug 31, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV will not turn on
Sounds like the power supply needs replacing.
TV repair is best done by a pro unless one has significant experience with it.
Charlie
Aug 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Fd Trinitron KV-32FX68E, stanby led blinks twice
odds are power supply module 150 200 repair
Dec 01, 2008 | Televison & Video
TV does not turn on.
Sorry, it sounds like to me that the power supply or high voltage circuits have failed. You will need to take it to repair shop.
Feb 19, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
133 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
