I just moved my whirlpool refridgerator. It was layed on its side for no more than 20 seconds. Once we got it to its new space, it was pluged in and now the refridgerator or the freezer will get cold???
    Problem Solver:
  • 5 Answers
When you laid the fridge on its side oil got on the head of the compressor and into the refrigeration system. the compressor is a vapour pump if you started it with oil still on the head of the compressor it most likely destroyed the compressors reed valves and piston.
Posted on Dec 10, 2008
Moved refridgerator to new house plugged it in will not come on lights or nothing. New had only 1 month. What would cause this?
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Apr 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Against my better judgement, I layed my refridgerator down during transport from one location to another. I waited approx. 12 hours before I plugged it in and it is not cooling properly. Is there...
Here is a tip that I wrote on moving refrigerators...if you did not do it this way then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is the best way
If you already have moved it wrong, you can sometimes get it working by plugging it in and unplugging it a number of times with an hour or so in between.
heatman101
Jan 16, 2011 | Whirlpool GS5SHAXN Side by Side...
Moved refrigerator about 2 miles it was laying on its side for about 20 minutes... got it to the second location have plugged it in and it does not work... what could be wrong????
When you laid it on it's side all the oil inside the compressor went up into the evaporative coil lines. The oil bypassed the seals inside the compressor. You should NEVER lay a fridge on it's side or back. It will never work right again, sorry.
Dec 09, 2010 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Alot of noise interference when I start the engine or turn on the refridgerator in the boat. Is it possible that there is a noise filter in the radio and this has gone bad??
It is [ossible if your unit came with a noise filter. Some times the wiring can get moved around and come into contact with other wires and cause interference. The best bet is to remove the radio and see if the radio wires lay next to other wires. If this is the case, you can greatly lower noise by moving the wires away from the non radio wires. If they must lay across each other, the less contact they have the better. MOve the wires so the cross each other at a 90 degree angle rather than laying next to each other side by side.
Jun 19, 2010 | Rockford Fosgate RFX-8320
Water dripping sound coming from new refridgerator
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan. This is the only source of water if nothing else is connected. Are you seeing and water anywhere.
Jan 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I just moved my dads fridge to my house and after about 7 hours I smelled a burnt plastic smell. I smell it on and off.The fridge is still cooling.When i moved it I layed it down.
When a fridge is layed down the oil in the compressor will flow into the refridgerant lines and will have to be stood upright until the oil can return the the comrpessor. It may be too late for yours but I would try cutting it off for a day before trying it again. This may not be the cause of the smell so keep a nose on that and try to locate exactly where it's coming from.
Aug 21, 2009 | Whirlpool GC5SHEXN Side by Side...
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Refergerator stopd working
did you check all the brakers? also did you lay it on its side? if so you need to wait 24 hours before pluging it in.
Nov 09, 2008 | Kenmore 53542 / 53544 Side by Side...
Moving
Enclosed find a link were you can get the answer for your question. http://en.allexperts.com/q/Moving-Furniture-2016/Moving-refridgerator.htm Good luck !
Aug 16, 2007 | Magic Chef CTB2125 Top Freezer...
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
