Question about Acer Aspire 7720-6155 Notebook PC
Going from a wireless g to an N---how
I have a acer 7720-6155 laptop with a built in wireless g and want better range and speed and want to upgrade to an N card ---how do I do that and do they make a card for the N
  • 136 Answers
Tiger Direct has a number of pcmcia 802.11n cards as well as usb adapters starting at $20. If you go that way you can disable the mini-pci card through your device manager.
Posted on Dec 10, 2008
Can I upgrade acer aspire 5330-2339 processor
Would not be worth it with the speed gain, better off purchasing a better notebook.
Jun 25, 2014 | Acer Aspire 5330-2339 Notebook
Is this laptop equipped with wirless connection fromthe manufactorere or must it be purchased
Most late model Acer Aspire laptops have G or N WiFi included in the computer. My Acer 3680 series has it built in (G) and I added a D-Link N card to it to speed things up.
There should be a switch on the front or a Fn Button that turns on the WiFi.
Dec 18, 2010 | Acer Aspire 5335-2257 Notebook
I have a acer 210t laptop with a 700 processor. can I upgrade to a faster processor and if so which one and how fast. Thank you.
Some laptops have "mobile" CPUs (physically smaller, and consuming less power) than the typical "desktop" CPUs.
So, if you know "how" to disassemble your computer, you may be able to remove the heat-sink & fans on top of the CPU, remove the CPU, and install a faster one.
However, if your current CPU is of the "Pentium III" series (which ranged from 500 Mhz to about 1400 Mhz), you may not be able to find a CPU that will be significantly faster than your current 1.26 Ghz CPU.
Instead, I would check the disk-drive -- if it is 4200 RPM or 5400 RPM, I would replace it with a 7200 RPM disk-drive, for better I/O speeds, and thus help your computer go "faster".
Also, I would add more RAM, again to make your computer go "faster".
Jun 09, 2010 | Acer Pentium III , 1.26 GHz Processor...
Wireless connection away from home
Here is the service manual for your laptop. It is 20 mb, so give it time to download and then make a copy for yourself on the laptop for a reference. Your laptop is equiped with a tri-band wireless card with a built in antennae that actually wraps around the LCD display inside the bezel. The switch to turn the wireless radio on and off is on the right front of the laptop. It is just left of the right speaker grill. Your laptop is also equipped with a bluetooth card.
http://tim.id.au/laptops/acer/travelmate%204220%202480%20aspire%205600.pdf
Oct 09, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Which HDD Supported To Acer4710z Laptop
Acer Aspire 4710 General
  • Built-in Devices Stereo speakers , Wireless LAN antenna
  • Width 13.5 in
  • Depth 9.7 in
  • Height 1.7 in
  • Weight 5.7 lbs
  • Color Black/light gray
  • Localization United States
  • Notebook type Thin-and-light (4-6 lbs.) , Budget
  • Screen type Widescreen
  • Wireless capabilities IEEE 802.11b , IEEE 802.11g
Processor
  • Processor Intel Pentium Dual Core T2080 / 1.73 GHz
  • Multi-Core processor technology Dual-Core
  • Data bus speed 533.0 MHz
Cache Memory
  • Type L2 cache
  • Cache size 1.0 MB
RAM
  • Installed Size 1.0 GB / 4.0 GB (max)
  • Technology DDR2 SDRAM - 667.0 MHz
  • RAM configuration features 2 x 512 MB
Storage Controller
  • Storage controller type Serial ATA
  • Storage Controller / Serial ATA Interface Serial ATA-150
Storage
  • Floppy Drive None
  • Hard Drive 120.0 GB - Serial ATA-150
  • Storage Removable None
  • Hard drive type Portable
May 30, 2009 | Computers & Internet
Want to download wireless internet to the system it is rum by windows 2003
What you need first is to install the wireless driver for your wireless card in your computer. If you don't have one you need to purchase a wireless card.
Then read the following info to decide what type of Internet access you require.
Wireless connections to the Internet can be achieved by several methods and it depends upon the method of delivery by the Internet Service Provider in your location.
The most common is by DSL and cable, the modems that are used with DSL and cable connection can have a built-in wireless router. Your computer will require a wireless card to connect to the modem/wireless router and the range is restricted to approx. 100 ft depending where the wireless router is located within the building.
The laptop's wireless card can be a built-in device or a plug-in device eg a PCMCIA card or a USB device. and these can also connect to a wifi hot spot in locations such as McDonalds. Star Bucks etc.
There is another method that can connect into the Internet that uses a USB wireless device that connects to a G3 network, bacically a type of mobile transmission and the device is locked into a specific Internet Service Provider. This method gives a wider mobile range (even across states) of connecting to the Internet but usually at a higher cost.
Basically you need to see what the Internet Service Providers offer in your location. Beware of the costs of the various plans they offer in broadband speed, their download limits and the penality for exceeding the limits etc.
When you decide which method you choose, you need to consider setting up your wireless network securely to prevent unauthorized access.
May 08, 2009 | Acer Aspire 3680 Laptop
Upgraded Acer 2500 Travelmate with a Wireless card
hey there is a external linksys wireless network adapter that works well it plugs in your usb slot
they are by linksys.
Linksys
Range Plus Wireless USB Compact Adapter should get you the correct range for around home and outside in your yard. check ebay for this solution its much cheaper here. thanks Kawuna
Dec 01, 2008 | Acer TravelMate 2500 Notebook
Wireless card
could you tell me if the onboard built in wireless on this laptop is working or not?, as it is built in and the wireless card will be conflicting, hense very slow and the pc not seeing the card as the main wireless connection and not booting up until removal of the card
Aug 14, 2008 | Acer Aspire 5050-3242 Notebook
Upgrade for acer aspire 4315
Hi, best and fastest way to increase your laptop speed is upgrading RAM to 4 Gigs, using 2x2Gb RAM modules like this one (UK seller).
Adding a bigger hard drive won't increase laptop speed, but will give you more space to store your files.
Another way to speed up a computer is using CPU overclocking, but this operation, good on old computers, is not worth on a computer with new CPU like yours.
On you tube also some user posted videos on how to upgrade chips on motherboard of old Acer aspire, but I suggest not trying this, as risk to destroy laptop is very high, and it is generally not worth.
Better to stick with traditional upgrades.
Aug 09, 2008 | Computers & Internet
Acer Aspire 7720-6155 Notebook PC Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
