The computer will not boot, says no boot filename received, disk read error occured. Help, I am not getting anywhere with it, I do not have the startup disks. What can I do?
SOURCE: Compaq Presario SR1520AN Boot failure
go into bios setup change boot so that cd/dvd boots first use winxp cd try to from it. or try to find Hirens boot cd. or a light version of xp that loads from cd
SOURCE: my computer wont boot anymore
Try going into safe mode by hitting F8 upon startup. If it lets you get into safe mode then choose "Last Known Good Configuration" on the menu. If that does not work then let me know, there are a couple of other choices.
SOURCE: still wont boot
Disk boot failure is usually a sign that your operating system has become corrupt in some way.
If you've got your Windows disc, put that in the CD rom, then boot the computer.
There's a "repair" option that you can select, instead of re-installed Windows.
That *should* fix the problem.
It's also (thought unlikely) possible that your hard drive has died completely.
SOURCE: a disk read error occurred
IF there more than One Hard Drive You must assign and master and a slave, If only one drive check connections again
SOURCE: Black screen error boot manager missing
sometime system restore wont work other solution might be to pop in your Xp or Vista cd assuming thats what you have.... and shut the Computer off and back on at start up during the first screen usually press F8 a couple times and select Option A and try the first option it gives you after that and continue down that list if it don't work then a reformat is the solution usually...
Press the "Enter" button.
Click "Launch Setup" when the Windows Setup page appears. When you click this choice and not the "Boot Legacy operating system" selection, you will not receive the "disk error" message any longer.
Adhere to the directions on your screen to finish the process of reinstallation.
hope this helps
