Question about ViewSonic VA1912WB 19" WideScreen Monitor
Viewsonic Monitor sound problem
Unable to hear sound from built in monitor speakers on Viewsonic model VX1945WM. All sound card drivers are installed with no conflicts. If I install external speakers the sound works. The internal monitor speakers did work at one point but just quit one day. Suggestions? The sound on my Viewsonic VA1912w quit working when I pressed the button on the On Screen Display "Restore Memory".I pressed the button in an effort to eliminate the flickering on the screen and that did not change. I subsequently downloaded and installed a Vista driver and the flicker was solved. As for the sound, when I press the buttons to go from ANALOG to DIGITAL, I get sound for a couple of seconds. When I press the power button I will get sound for a couple of seconds before the monitor goes off. I have twice spent more than an hour with Viewsonic Tech Support and they have no solution.
  • 1 more comment
  • Anonymous Jan 05, 2009
    Problem is sometimes I have sound and sometimes I don't. Working fine then sound goes and error NO audio output device is installed. When the damn things worked last time. I turn off for a while and back on Vista finds them.
  • Anonymous Apr 12, 2009
    are these monitors just w a n k...! I have the excact same problem!! can anyone help???? before i make my own modifcations with a club hammer....
  • Anonymous Apr 29, 2009
    souhnd doesnt work
sandrew
  • 2961 Answers
SOURCE: Monitor Flickering and Sharpness control is disabled
it will probably be the graphics driver you need to update as XP probably loaded generic a graphic driver. The monitor should be ok with a standard driver.
Posted on Apr 18, 2007
SOURCE: VX1945wm not working
do u know how dissarm it ?
thanks!
Posted on Apr 07, 2008
  • 7 Answers
SOURCE: ViewSonic VX922 monitor - black screen - green power light flashes
PLEASE read Carefully so here is a fix for the green blinking light ...the monitor is going into shutdown....protect mode......THIS is ...Only for the seasoned electronic service tech ......YOU NEED TO BE into Electronics ..or have electronic background and know how to solder to do this........I been doing repairs for 30 years now ..............After extencive troubleshooting and replaceing a lot of electrolitic caps on the inverter board and spending about 10 hours doing so ....i decided to eather go for broke and blow this up more or trash the unit......................Well my blinking light deal went away...my monitor you could see it trying to start and just shut down............first of all make sure you have no broken solder work on the inverter board or swelled up caps ...Thay use lead free solder so the solder work sucks also...........I did pull the main buss line from the inverter pc board that runs the transformers to test to see where the trouble is.....found its at the high voltage end of the inverter board and The viewsonic 922 uses a protection ic on the inverter board and it tells the controll ic whats the High voltage status of the inverters.....I soldered a 47uf @ 25 volt cap on pins 7&8 of ic-u2 [ bi3101a ] Pin 7 is posivtive pin 8 negative of the cap.... and then soldered pins 10 and 11 togeather on the other side of the ic.......ITs fooling that ic telling the main controll / protect line thats all is well........I would guess the whole deal is LOW inverter voltage or maybe a surface mount device thats going to go........could be low resistor tolerence also............The monitor been working for a week now.........Always on.....anyways........YOUR problem may just be bad solder or bad caps...........if you Have a electronic background or have a friend that works on electronics have him look at the caps.see if any or swelled or rounded on the top of the caps..Also chect the main plug that goes to the LCD backplane to make sure its in correctley................if all that checks then the problem is ON THE INVERTER BOARD ONLY ......befor doing what i have done......I also have a Viewsonic VA-800 that had some of the same problems also ,but it had a lot of lines on the video.......I replaced the,,,,, 2.2 mic @ 50 volt cap in the middle of the main board on it and its still running.....but has about 3/8 of white traces following all the words on the desktop...[[[ anyone that knows this fix i would like to hear from ]]] ..........NOTE if you dont know about electronics...dont attemp any of this......their is a lot of voltage on the inverter board........my answer is that these monitors are JUNK...poorley built units.....
Posted on Oct 05, 2008
nivlek_821
  • 60 Answers
SOURCE: My Viewsonic monitor won't switch on, occaisonally
the power is the problem...try to fix the power cord....
Posted on Nov 07, 2009
budmrtn
  • 11361 Answers
SOURCE: Half way through pc posting screen goes blank
Common failures in this monitor is the 470uF caps in the inverter section (close to the inverter transformers), but you should replace all the caps in the 5vdc and the 12vdc as a whole set. See example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 28, 2010
What should the connection from my vx2250 viewsonic monitor to my desktop look like?
If your monitor has built-in speakers, you should have a connecting cable with stereo mini plugs on both ends installed between the line out connector (usually green) of your sound card and the audio input connector on the monitor. I have an HP monitor with built-in speakers and that's how it is connected
Nov 08, 2012 | Viewsonic Corporation Viewsonic...
Sound no longer comes out of monitor. I believe nothing is muted. I replaced cable between monitor and desktop. Any suggestions.
You didn't provide a model for your Envision monitor, so I can provide specifics - but here's a few things to try: (1) Start an audio program on the computer (mp3, CD audio, movie, etc. (2) Disconnect the audio patch cable from the computer's speaker jack and plug in stereo headphones. Adjust the volume on the computer's audio control panel to set the volume. If you're not receiving any sound - make sure you're plugged into the speaker jack (this is often the green jack). If you now hear sound, continue to (3). If you are unable to hear any sounds - your problem is INSIDE the computer. More on this later. Continue to the next step. (3) Disconnect the headphones and try the audio patch cable between the computer and monitor again. Make sure you're using a stereo cable - it has 2 individual contact points on the plugs - mono cables have just two. Pay close attention to the jacks if more than one are offered on the monitor (some monitors have power output jacks, etc.). Select the "LINE IN" or "SPEAKER IN" jack on the monitor. Be sure the plugs are firmly seated into the jacks on both the monitor and computer. (4) Check the menu settings of the monitor to make sure that the speakers are enabled (or not disabled as the case may be).
if you were unable to hear audio in step (2) above, there is a problem with the audio circuit in the computer. Some things to check are: Is there a volume knob on the sound card that is turned to minimum? Are (all) the correct drivers installed for the sound card in control panel? Is the sound card enabled? Does the sound card have a problem indicated by an "x" or "!" on the icon in control panel? Many times, "uninstalling" the device in control panel and the "scanning for changes" to reinstall will solve the problem. Other times, it is an output device issue: Have you selected "Speakers" as the output (not HDMI or Digital Audio).
If still unable to get sound working, provide the Envision model number along with computer name & model or the sound card name and model. If the sound is built into the motherboard, provide the mother board name and model. With that info, it will be easier to get the info you need.
Hopefully, you got the sound working with the tips I provided above. Please rate my reply. Thanks.
May 23, 2011 | Envision Computers & Internet
Speakers on monitor are not making any sounds... how do i check
VX2255 does not have built-in speaker, see spec here: http://www.viewsonic.com/products/desktop-monitors/lcd/x-series/vx2255wmb.htm
It has built-in webcam and microphone.
Please verify the model.
Oct 01, 2010 | ViewSonic VX2255 Monitor
Hi , I own a viewsonic LCD monitor model va1912w. My system has Windows XP. There is no sound from the monitor even after connecting the sound cable from CPU to monitor's audio jack. I have already...
http://www.viewsonic.com/support/downloads/drivers/?prod_name=1912
Try the above link for Vista or XP drivers which may be used with Windows 7 in some cases.
The va1912wb came up when I searched under 1912.
This driver is available directly from the viewsonic.com site.
Uninstall the other driver if possible.
Aug 08, 2010 | ViewSonic VA1912w 19" LCD Monitor
No sound
you need to reinstall your soundcard on the computer
Dec 06, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Drivers cannot be loaded...windows does not recognize monitor
I think after your crash you are missing the drivers for your graphics card and not the display. Check what kind of graphics device you have and see if you can find the drivers for that.
Sep 20, 2008 | ViewSonic VX1945WM LCD Monitor
LCD Monitor's Audio Is Not Working
First.. have you installed the drivers for the sound card.. would check that first.. if that is ok.. then check the output of the computer with another pair of speakers or a pair of headphones.. additionally i would check the speakers in the monitor by connecting to another source.. such as an mp3 player or portable cd player..
Sep 07, 2008 | ViewSonic VX2035WM LCD Monitor
Hi check the sound cable hasn't fallen out or come loose from the back of the monitor. After this reinstall the drivers for the monitor you will be able to download them from viewsonic if still not working then the speaker jack or speakers are faulty.
Hope this helps
Thanks J
Jan 20, 2008 | Computers & Internet
thanks!
Dec 13, 2007 | ViewSonic VX1945WM LCD Monitor
No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
make sure you hook up the third gree socket on back of monitor to PC that was my problem and solution to my model monitor LCD
Sep 17, 2007 | Liquid Video E15LCD1 15"
Computers & Internet Logo
2,896 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
