Question about HP PSC 2410 All-In-One InkJet Printer
Hp psc 2410 photosmart
My printer is suddenly printing documents which are incomplete. There are white boxes in the area where the image is supposed to be. Any solutions? Thanks
    President:
  • 2,961 Answers
There must have been a settings change in the printers properties or the programme that your are using to instruct the printer to print text only and not the pictures. Sometimes printing web pages direct from the net have the problem, as pictures are left out purposley to aid printing speed.
Posted on Mar 02, 2007
Hp psc 2410 photosmart driver win7
HP no longer provides support for drivers for this printer. The newer Windows OS will support the printer natively, but sometimes it requires a little finesse from the user. Here is a link to an HP forum where folks tell how they worked out the communications issue for the print and scanning functions. Hope this helps!
adding hp psc 2410 printer to windows 7
Aug 01, 2016 | HP PSC-2410 PhotoSmart All-in-One Color...
Hp psc 2410 photosmart all-in-one printer suddenly started printing very slowly. The ink jet cartridges are new. I even tried replacing the cartridges and that didn't work either. I tried resetting...
Welcome to Fixya.
You can try the following to remedy this problem as I had experienced it myself and was able to resolve it through the following means :
  • Remove the top lid, unscrew the 5 screws, 2 on the left, 1 on the top (under the lid), and 2 more hidden under the grey board which can be remove with caution.
  • Once opened, clean up the glass with some special clean-up liquid and dry. Clean-up the white square also under the lid.
Put the pieces back together carefully and try printing out.
Hope this helps, Thanks for using Fixya.
Jun 11, 2011 | HP PSC 2410 All-In-One InkJet Printer
HP 2410 photosmart all in one, copies and prints extremely slow, it will eventually print the job but it might take 20 minutes, ant idea of the reason?
Probably you are printing very high quality images/documents. Try reducing the DPI's in the settings. That should help
Apr 09, 2010 | HP PSC 2410 All-In-One InkJet Printer
HP psc 2410 photosmart all-in-one not piking up paper
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 16, 2009 | HP PSC 2410 All-In-One InkJet Printer
My hp psc 2410 photosmart printer will not print - only copy
Check to make sure your PSC 2410 is in fact the default printer. If it is, make sure your cable is firmly plugged in to your printer and CPU. Clear the print queue. Turn off and restart printer. I have found that your problem is basically a communication problem between the computer and printer. Also check www.hp.com. Good luck.
Feb 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
PRINT COMES OUT TO SMALL
Hi, my name is Sam, and I think I know how to help you. First please press, start and go to run then type "control printers" in the text box. that should bring up you printer icons and click on you printer icon. A box should come up titled something like HP PhotoSmart PSC 2400 Series, go to the Printer menu and click on Printing Preferences..., go to the Effects tab and set "% of normal size" to 100 % of normal size!
Oct 28, 2008 | HP Photosmart 2410 All-In-One InkJet...
Scanning with hp psc 2410 photosmart all in one
Hi flipflop8
intact it is the windows update which has messed up ...
do one thing install the software completely and do not open HP director.
then download the full feature software for a higher version photosmart printer .keep the printer connected and powered on
start the installation for the higher version priner .. when it prompts for installation type chose advanced type then chose custom install. in the next window put a check in the drivers, solution center & photo and imaging device. click next ,it ll prompt u to connect the device . check the box which says connect later and complete the installation.. in this process HP director ll be over written with hp solution center open that from desktop shortcut and scan
to download the software CLICK HERE
Apr 30, 2008 | HP PSC 2410 All-In-One InkJet Printer
Not printing text
with a wet paper clean up the head of the cartridge, and let some tint go to the napkin, or paper :) Resulted for me
Dec 21, 2006 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
66 people viewed this question
Clive
Clive
