Question about Sony VAIO PCV-V210P PC Desktop
Sony vaio not loading windows
Question
I've been running Windows XP on a Sony Vaio laptop for months without any difficulty whatsoever. Today I turned on my computer as normal and immediately got the following message: We apologize for inconvenience but Windows did not start successfully. A recent hardware or software change might cause this problem.
Your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders.
Choose last known configuration to reverse to the most recent setting that worked.
If a previous start-up attempt was interrupted due to a power failure or because the Power or Reset Button was pressed, or if you are not sure what caused the problem, choose Start Windows Normally.
SAFE MODE
SAFE MODE WITH NETWORKING
SAFE MODE WITH COMMAND PROMPT
LAST KNOWN GOOD CONFIGURATION (YOUR MOST RECENT SETTING THAT WORKED)
START WINDOWS NORMALLY
Use up and down arrow keys to move the highlight to your choice." Nothing works and my PC just restarts every time. I can not even get into safe mode. Can you help?
  • 1 more comment
  • joshharris91 Dec 10, 2008
    i am having exactly the same problem with my compaq presario C300 and i dont know what to do aswell this is the first time it has ever happend to me and i have been using the laptop for almost 2 years now
    i have also been having the exact same problem with my compaq presario C300 laptop i have been using mine for almost two years now and this is the first time i have ever seen a message like this. i just don't know what to do.
    how do you reinstall the OS and overrite the previous XP?
    Scholar:
  • 176 Answers
Reinstall the OS ! Just overrite it over the previouse xp so u won;t lose data ...
..most probably u are missing some files ... .. or u have virusez issues. Ofecourse there is the posibility of hardware mallfunction, but considering microsofts reputation ... probably thats not the issue ...
Posted on Dec 10, 2008
Forgot Sony Vaio password
I met the same difficulty for the previous period,and I know the easy an effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from http://www.windowspasswordreset.net and install it on other unlocked computer.
Tip2:Burn Windows Password Reset to CD/DVD or USB.
Tip3:Insert newly created CD/DVD or USB to your computer which you forgot its password and reboot it,and follow the instruction that follows.
I hope it can help you soon.
Jul 25, 2012 | Sony Computers & Internet
I can not turn on my Sony Vaio laptop. when I press the on botton it shows vaio and windows xp as if its starting then it keeps on doing same procedure without turning on to windows xp for use! Thanx.
use a windows setup disc and check for problems on your installation, it sounds as if a driver update is causing the laptop to crash , hence why windows is not starting. Have you tried entering safe mode? Are you able to start windows this way?
Mar 13, 2011 | Sony VAIO VGC-JS110J/S Notebook
Hi i want to change my windows from vista to xp i want xp drivers for sony vgn ar 720 how can i install on this computer without further truble and difficulties? thank you
hello there
you mean you want to down grade your system? yes! you can but need to fresh install and need to format your c: drive, it means also, you need drivers components for windows xp.
thnk you
Mar 08, 2011 | Sony VAIO VGN-AR720 Series Laptop Charger...
Sony Vaio VGN-CS12GH xp installation problem
in biso change tha sata mode to ide the try.
Oct 20, 2009 | Computers & Internet
Can I run a Sony Vaio VGN-FS980 laptop closed?
You should be able to go into power management utility whether it be sony or Windows and change the "when lid is closed" option from hibernate/shutdown to "do nothing"
on XP
CP>Power Options>Power Schemes
Jun 10, 2009 | Sony VAIO VGN-FS980 Notebook
My VGN FS920 shuts down at the window loading screen
ok no need to get a bcakup disk or downlaod anything
if ur hard drive is original factory fitted
and
ur laptop came with pre loaded OS as XP
then do this without disk
Sony: When you first turn on the laptop and see the VAIO logo screen, press the F10 key (you need to do this before the VAIO logo disappears).
pls let me know and rate me FIXYA for help
Mar 31, 2009 | Sony VAIO VGN-FS920 Notebook
Sony vaio not loading windos
Try booting XP with the installation CD & use the recovery console to boot the laptop.
From the Setup CD-ROM
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
To exit the Recovery Console and restart the computer, type exit.
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
Sony Vaio sound...
Adam,
The sony VAIO Pcv-j200 only runs with Windows 2000, windows Me and windows xp. The current operating system Vista on your computer right now will work but some of the features of it may not. The link below shows all the drivers for your unit for diffent operating systems (not vista). What you can try to do is to download the audio driver for windows xp
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVJ200&LOC=3
Jul 05, 2008 | Sony VAIO PCV-J200 PC Desktop
DRIVERS
You can download it from sony website for free!!
Apr 12, 2008 | Sony VAIO VGN-AR230G Notebook
Camera not connecting to computer
You'll need to update the camera software for use with Vista. The Vaio isn't the problem. Thee updates for the F20 can be found here: FujiUSA
Mar 16, 2008 | Fuji FinePix F20 Digital Camera
Sony VAIO PCV-V210P PC Desktop Logo
421 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
