Question about Canon MultiPASS F80 All-In-One InkJet Printer
Cannon multipass f80
Check printer press resume key ##335. what do i do?
jeffRan out of paper, reloaded, get message check printer press resume key. When pressing resume key, hear loud noise near paper tray and displays same message. I cleaned everywhere and no change.
    Top Expert:
  • Canon Master
  • 70,387 Answers
Unplug the printer for 3 minutes and plug it back in.
Posted on Dec 10, 2008
  • 734 Answers
Hi,I would suggest you to first trying unplugging/ switching off your device for 5 minutes. This restores and refreshes the device. Go for it
Let me know if this works, if it doesn’t then I’ll provide some other alternative solution.
Thanks
  • futureloginn
    futureloginn Dec 10, 2008
    1. A method of controlling noise in an impact printer, comprising the steps of: a) generating at least two distinct positive input pulses of voltage and applying them to a power amplifier of the impact printer, whereby a solenoid winding current waveform is created; and b) applying said solenoid winding current waveform to print wire solenoids to create a single force having a reduced repetitive spectral envelope containing problem harmonics.
    2. The method of controlling noise in an impact printer in accordance with claim 1, further comprising the step of modulating said input pulses.
    3. The method of controlling noise in an impact printer in accordance with claim 1, further comprises the step of shaping said input pulses.
    4. A system for controlling noise in an impact printer, comprising: a print wire solenoid; a power amplifier for supplying power to said print wire solenoid; means for generating at least two distinct positive input pulses of voltage and applying them to said power amplifier, whereby a solenoid winding current waveform is created; and means for transmitting said solenoid winding current waveform to said print wire solenoids to create a single force having a reduced repetitive spectral envelope containing problem harmonics.
    5. The system in accordance with claim 4, further including a Complex Programmable Logic Device (CPLD).
    6. The system in accordance with claim 4, further including a Field Programmable Gate Array (FPGA).
Alarm button is blinking and paper is not fed in machine
You need to look at the display (LED window) to see what is displayed. It will give you an error message such as "Clear paper Jam," etc. If nothing is displayed, press the "Resume" key to the left. The light should go off.
Jan 22, 2011 | Canon MultiPASS F80 All-In-One InkJet...
My multiPass F80 alarm is flashing a check printer press resume key code and I not able to clear it this happened after I stopped it in the middle of a fax mode
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Dec 02, 2010 | Canon MultiPASS F80 All-In-One InkJet...
Check Printer and Press resume key message along with Alarm light
Too many things can cause that, paper jams, carriage errors, printhead problems, purge assembly errors, feed roller errors, need more info to be of any help.
Aug 12, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Canon Multipass F80 printer. "Check printer press resume key"
On the f80 you need a shop to go to service mode and get the error code and tell you what the problem is. Could be purge assembly, waste ink full, feeder error, printhead error, any number of possible problems.
Aug 05, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Check Printer Press Resume
try a new print head part # QY6-0041-010 I had the same thing happen I replaced it and it works fine I even swaped the ink from the old one to the new one
Jan 28, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Waste ink cartridge full
Maybe it waste ink
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 27, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Check Printer Press Resume button
When your printing? thats the problem? Remove the USB cable then turn off the printer, then turn on it again and plug in the USB cable on the USB port. See what will happen?
Feb 28, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Alarm light on. F80
This worked for me on an F60 and someone else on an F30. Re: Check Printer error message on Canon MultiPass by watsonk (6/7/05 11:16 PM) reply + / - It could be due to "waste tank full" alarm; you may need to reset the waste tank counter. I found a reset sequence for a MP730 printer in this website that works for F30 as well. Try: Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key. Skip step (6) since there is no [OK] key on F30 printers.
Sep 29, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Multipass print head stopped working
try to move the printhead left to right. and make sure there is nothing obstructing it. Also make sure you ink cartridges are in securely. If that doesnt work let me know.
Jun 28, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Canon MultiPASS F80 All-In-One InkJet Printer Logo
239 people viewed this question
old marine
old marine
Corne Viljoen
