Question about Edirol UA-1EX Sound Card
Edirol UA-1EX - hearing noise on audio playback
I pretend to use the UA-1EX as a USB audio interface between a "Sony VAIO FW-21M" laptop (with Windows Vista 32 bit OS) and a pair of powered monitors "KRK RP6".
I installed the driver and the audio device works fine if the laptop is on battery mode, as soon as I connect the laptop's AC power to a socket (all the sockets were tested and they have electrical ground) I started to hear a loud noise/distortion (like radio static) through the monitors in the audio playback.
I checked all the items from troubleshooting in UA-1EX owner's manual and I can't solve the problem, there's no mic connected, or a microwave or a TV nearby. In the room is just the laptop, the UA-1EX and the monitors.
To test the UA-1EX, I connect it to a "Macbook" and it works fine with clean sound (battery mode or plugged into a socket).
To test my "Sony VAIO", I connect it to a "Native Instruments Audio Kontrol 1" audio interface and it works fine with clean sound (battery mode or plugged into a socket).
So, apparently all the devices are OK, but the truth is when I try to plug my "VAIO" laptop's AC adapter to a socket, the UA-1EX can't filter the static (or whatever is that noise that starts) and passes all that noise to the monitors make it impossible to have a clean sound, consequently it's impossible to produce any kind of work, and the laptop is connected to electrical sockets 99% of the time.
Notes:
_As I said before the UA-1EX worked fine with a "Macbook". Both "Macs" and "VAIOs" have AC adapters, but while the "Macbook's" AC adapter transforms 220V (Europe) into 16.5V, the "VAIO's" AC adapter transforms 220V (Europe) into 19.5V, I don't know if it could be important.
_The only thing I couldn't check in the UA-1EX owner's manual troubleshooting was the item "Advance Power Management Support" and "Don't Poll Power Supply Status", can't find this in Windows Vista Device Manager, only found the battery power management but it's useless.
I really appreciate that you could help me to solve this.
  • stoutheartus Jan 12, 2009
    Background internal noise from Dell XPS 1330 Laptop audible while using Edirol UA-1EX soundcard. Unit works great on different dell laptop. Used to work quietly in this laptop. I will keep searching for the solution.
    AGS
  • Anonymous Mar 11, 2009
    How did you changed it to a recording device
The UA-1EX can supply phantom power to condenser mics so the issue with the noice is a ground loop problem between the UA-1EX and your other devices (laptop/amps in the powered speekers.) I had the same problem so I found a Direct Injection box (D.I.) that allowed me to convert an stereo RCA Signal to two balanced XLR signals or vice versa. Whirlwind is the brand of mine. There should be two grouding switches on the DI that will allow you to ground the UA-1EX and get rid of the noice. Hope this helps.
Posted on May 08, 2009
No solution, but I had the same issue with my old laptop, I tried everything, the only thing that worked, was to use a voltage generator, set it to 19.5 V (this was what my laptop was converting to) and getting a laptop power plug and creating a connection. Because the power pack is a SMPS, it was very noisy and this noise would be transferred to the recording.
Question of my own, where did you find drivers for Windows Vista 32 bit? I can only get my UA-1EX to run as speakers, not a recording device!!! HELP!
Submeg
Posted on Feb 07, 2009
  • Submeg Feb 08, 2009
    Worked it out, Vista was setting it as a speaker device, once I changed that setting, it now operates as a recording device
When i playback in WDM mode, i hear ckrackles and pops, when i playback in the other mode the ckrackles and pops are gon, but the input and output goes to none. how do i get rid of the ckrackles and pops...
1. check your user manual for clicks/pops.
this could be due to devices connected to the Edirol UA-25 or a television or microwave.
2. this also could be due to the setting in Windows Energy saving settings.
that is the Windows "sleep mode" and power saving mode.
3. this could also be due to the USB cable.
4. you may need an external filter device for the process you are using.
5. read your manual on Troubleshooting Noise ( clicks and pops).
Jun 14, 2011 | Edirol UA-25 External Sound System
The output is coming out of the wrong side of the headphones (i.e., suppose to present sounds on left, comes out on right headphone)
You will need to reinstall the drivers
If that doesn't work...you will need software that allows you to invert the sound.
Please rate if this helps!
Mar 03, 2011 | Edirol UA-1EX USB Audio Interface
Hi. I have a problem with my edirol ua-1ex. When it is on my computer, some minutes after, it blows it, the blue message appears in my screan and shut down my system, i don't know why, everything seems...
It sounds like this may be a driver related issue. Can you please try downloading the latest version of the driver for your operating system from the link below and installing that to see if it resolves the problem.
http://www.roland.com/products/en/_support/dld.cfm?PRODUCT=UA%2D1EX
Robert from Blitware
Jun 16, 2010 | Edirol UA-1EX Sound Card
Having trouble with audio cutting in and out du internet playback
thisn is called buffering, youn dont have enough internet speed to allow the sound to load ahead of the play mode.
Jun 20, 2009 | Edirol UA-1EX Sound Card
No MIDI Interface on Laptop
I would expect that to work fine. I have used several USB to Midi adapters with good results.
Dec 17, 2008 | Edirol UA20 USB Audio/MIDI Interface...
Edirol UA 4FX _Short Audio Signal dropout
try runing a cleaner ccleaner and ace utituies ok that stop those hickups give a atry make pc run alsot faster
Jan 28, 2008 | Edirol UA-4FX External Sound System
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Mic problems: playback works great through interface, microphone isn't being detected
Check in contraol Panel under sounds and audio devices that you are using the Edirol and not an on board sound. It sounds like although the cards installed its not selected as the audio device to record from. You will also have to tel Adobce audition to select the Edirol as you audio card of choice as it to can be changed to select input from other sound devices.
Mar 31, 2007 | Edirol UA-25 External Sound System
Edirol UA-1EX Sound Card Logo
809 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
