Question about Sony NW-E003F MP3 Player
How do I turn it off without running the battery charge out?
How do I turn it off?
    New Friend:
  • 161 Answers
Hi Carol try visiting this site and download the manual http://www.sony.lv/product/nws-e-series/nw-e003f#pageType=manual
(if this helps you please rate the)
Posted on Dec 10, 2008
How do you tell if it needs charged or not?
Hi Kelly, A fully charged battery is 12.4 to 12.6. and when the motors running it's 14.3 to 14.6... Three reasons your battery is flat (isn't charging), You have a faulty battery, A power drain or you have a faulty alternator... Clean your battery terminals and If you don't have a multimeter then Try jump starting your flat battery and driving your car for at least ten minutes then turned the motor off and try starting it WITHOUT jump start, If the battery's still flat then it's the battery, If your car starts straight away but won't start the next day then you have a power drain... If you jump start your flat battery and go for a ten minute drive but during that drive the motor dies without turning off the key then it's the alternator....
A mechanic or an auto electrician can usually test Free of charge if you can get it there....CHEERS..
Apr 16, 2016 | Cars & Trucks
My AceAcer aspire 7720z only charges when turned off but when turn off without the battery thus using only the adapter, it shows the orange light and goes on within 10 - 15 sec. Can someone help me plsssdd
Has it always only charged with the battery when it is closed, because that is very unusual. Most likely your li-on battery is dead or only holding a minimum charge. Most older laptops will not run without the battery or if the battery is dead. if the battery is not good it will not power up. You need a new battery, or get that one rebuilt at batteries plus or sonewhere.
Jan 04, 2015 | Computers & Internet
HOW DO I TEST AN ALTERNATOR
Most likely yes. If you can charge the battery (get it tested after charging as well) up a quick way without any special equipment to find out if your alternator is charging is with as many electrical loads turned off as possible (heater/a/c blower, headlights,heated seats,stereo etc...) Start the engine (after battery is charged) remove one of your battery cables while the engine is running, if the engine immediately stalls your charging system is not charging. If it stays running it is charging. Do not reconnect cable until you turn the engine off to prevent damaging the alternator.
If it stalls the most likely reason is the alternator. There are still other things that may prevent it from charging. Many alternators are regulated by the computer so it could be a computer or a wiring issue or even a blown fuse. If you can remove the alternator without much difficulty then remove it and take it to a auto parts store and have them bench test it. Last but certainly not least make sure your cables are clean inside and out. An alternator cannot charge a battery with poor corroded connections.
Dec 05, 2014 | 1989 Nissan Pathfinder
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
Car will turn over and wont crank at times
Your alternator isn't charging your batter and needs to be replaced, your battery no longer holds a charge or doesn't have enough cranking amps for the application and that only applies if you aren't playing your music without the motor running. If you play music without the motor running it's going to drain your battery, sure, it'll still play music but the amps will be too low to turn the motor over fast enough to catch the timing on the motor in order to start it. Winter is hard on batteries as well, that's why they have cranking amps and cold cranking amps.
Mar 04, 2011 | Car Audio & Video
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
Your battery is dead when it no longer will hold a charge. Replace your battery.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
2002 Jeep GC will not idle
If the battery does not hold a full charge the vehicle will not idle, replace the battery
Apr 16, 2009 | 2002 Jeep Grand Cherokee
Unable to charge battery or use without battery....
That is kinda odd... And it will not run What So Ever without the battery? Not much you can do in this case, you may need a new battery. Otherwise leave the battery on charge for 12 hours strait and see what that does.
Nov 25, 2008 | Computers & Internet
Sony NW-E003F MP3 Player Logo
148 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
