Question about White Sewing Superlock 1934D Mechanical Sewing Machine
Tension settings for a rolled edge
I'm trying to set white superlock 1934 d up for rolled edge napkins....and my chart for tension setting is missing. cna you help?
  • Anonymous Mar 29, 2014
    How do I set the tensions for sewing a wolly nylon edge on a denham bib?
    Problem Solver:
  • 5 Answers
3 Needle
1-3 Upper
7-9 Lower
1-2 Stitch length
Tension .7
Stitch finger 7
Posted on Sep 09, 2009
What is the normal setting for the differential knob on a White 2000 superlock ATS?
Here's a manual for your machine. The differential settings are discussed in Part 2:
Instruction Manuals
Input "2000 ATS" in the search box.
Jun 15, 2016 | White Sewing Superlock 2000 ATS Mechanical...
What are the normal settings on a white speedy lock 234DE serger
Normal setting will depend on what you want to do with your machine. The standard factory tension setting is the mid-point of each thread dial. However, if you are doing a rolled edge, you will need to consult your manual to determine where each dial should be set to deliver the results you seek.
Sep 25, 2015 | Sewing Machines
Brother serger 634D
try new needles
make sure the threading is correct, using every guide
make sure the tension is set correctly
Apr 10, 2014 | White Sewing Superlock 1934D Mechanical...
Need manual for white 1934d
Go to www.singerco.com and under customer support put in 1934 and download it for free. Good luck
Sep 26, 2010 | White Sewing Superlock 1934D Mechanical...
White Superlock owners manual missing
i was able to find manual at www.ifixmachines.com
Jan 22, 2010 | White Sewing Superlock 2000 ATS Mechanical...
White Superlock 2000 ATS--setting for lettuce edge?
Hi, getting a lettuce edging on knit is not in the settings . To get this effect, you need to stretch the fabric as you feed it thru the machine. Try it on a scrap first to get the right effect, then try it for real,
May 02, 2009 | White Sewing Superlock 2000 ATS Mechanical...
White serger 2000
Did you change to the narrow stitch finger? The narrow one is in the door of the machine where the other tools are -- a little square box on the left of where the needle box slides in. Sometimes that is needed instead of the normal one.
Caution: If you have never before changed it out, open the left door all the way and look and see where the stitch finger is coming out of before you remove it all the way. Refer to your manual.
Oct 13, 2008 | White Sewing Superlock 2000 ATS Mechanical...
I have a white superlock 228 jaguar serger problems with right needle
Couple of things I could think of: tension disks need cleaning, there is a site that tells how to clean them, maybe 2 as I recall. Other thing is it is a much older serger, (I have one I am slowly working on to bring up to working level), so it could be that a tension spring internally has lost its tension. It might need a trip to the repair man if that is the case. Another thing is are you using correct needles for the machine? Have you changed them recently? Even new needles can be bad, so if you have to change three times to triple check it can be worth it.
Aug 14, 2008 | White Sewing Superlock 2000 ATS Mechanical...
White Sewing Superlock 1934D Mechanical Sewing Machine Logo
201 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
