Question about Baumatic F60 Stainless Steel Kitchen Hood
Light blown then fan doesn't work!
This is a white baumatic QF6CW 60 hood and in nearly 2 years old. One of the lights blew and they are standard screw in candle bulbs. When this happened the fan then stopped working. I just wondered does anybody know if there is a fuse or something as now both lights dont work with new bulbs nor does the fan. Thanks
  • 3 more comments
  • Tricia C Dec 29, 2007
    Light has blown but fan is still working. New bulbs put in and still not working.
  • Anonymous Sep 01, 2008
    no fan working or lights
  • Anonymous Mar 26, 2014
    lighbulb blew now fan won't work, I checked the fuse, and all ok, and cheked the plug in the cupboard and tried something else and all ok, I seem to think it may be a fuse on the rangeheed, but not sure why the lights and fan wont work? I haven't tried a replacement lightbulb yet, i will give this ago later today. Any idea?
  • Anonymous Mar 29, 2014
    I recently replaced the motor so I don't want to scrap it.
    Bulb blew on my BT7.3GL. changed bulb,fuse and PCB.Fuse on circuit board ok. Power is getting to circuit board. What now.?
    President:
  • 1,462 Answers
Take out switch assemby and check if the track of the pcb is blown - caused by the bulb goiung. you can often repair by soldering in wire links. bet you have 12a fuse in system - should be 3a. track has blown instead of the fuse
Posted on Mar 31, 2007
SOURCE:
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
The light blew on my Beaumatic F60 extractor fan, thought the bulbs had gone so changed the bulbs, they lasted a couple of minutes before blowing again and then the fan wouldn't work also. I can't find a...
Look at the instruction/installation manual.
Are the bulbs 12volts or 120vac? If it is 12v there is a transformer that might be shorting to ground. If no transformer, the control panel or the control board has a short.
Mar 11, 2011 | Baumatic F60 Stainless Steel Kitchen Hood
Had Blinking RED blinking lights. FIXED
CHECK LAMP COVER, CLOSE IT AGAIN THE RIGHT WAY
Feb 21, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Baumatic hood bt82.1 lamps blown..
Hi johnnyi6,
I'm Harvey the Master Plumber.
Your problem is: had a crackling noise then pop..looks like transformer has blown,replaced
but still no lights ..fan o.k...don't appear to be getting any power to transformer via switch?...how do you get push button switch out?...
bypassed light switch and lights o.k with new transformer..any ideas..
Yes, I agree, the switch went bad. It snaps in so you will break it during removal. I recomend you get the replacement switch first so you don't have a wire hanging out while you wait for the new one.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 15, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
The extractor on my Baumatic fan stopped working. Thsi was shortly after the light bulbs blew which I replaced and they work OK. Any suggestions as to how i can resolve this?
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Jun 05, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Baumatic F60 Stainless Steel Kitchen Hood Logo
1,014 people viewed this question
Top Baumatic Kitchen Ranges Experts
Norman Al-Anbar
ray gallant
ray gallant
Jay Plesset
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
