chk of you get the link light if not then contact the ISP if yes then shut down the system unpluged the modem from the system and remove th power cable from the modem and press the power button and hold it for 7 sec or reset the setting of modem by presssing the reset button and turn on the system without connection the modem to the cable once you see the the windows is loaded completly connect the modem and try it (leave the modem unplugged atleast for 3min) or try to run msconfig and disable the startup items and try it agian
Could be a variety of reasons. Assuming you have not had it working before Assuming the wifi is broadcasting it SSID Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R type cmd and enter type ipconfig and enter note lower set of figures ie 192.168.0.1 open browser and type in those figures and enter should now open router firmware When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
wont to know if theres any way i could reset my labtop cause i can not get into my windows due to...
(More)
wont to know if theres any way i could reset my labtop cause i can not get into my windows due to the password
Hi! Laptop Compaq,1 month ld,cat was walking on a keyboard,cusror doesnt move any more(no mouse)...
(More)
Hi! Laptop Compaq,1 month ld,cat was walking on a keyboard,cusror doesnt move any more(no mouse) What to do???thank you!!!
when pressing my wifi on button on my acer aspire 3000 lap top it shows no device what does this...
(More)
when pressing my wifi on button on my acer aspire 3000 lap top it shows no device what does this mean
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
