Question about Uniden Cordless Phone
GE Cordless Phone Set - Ringer will not ring
The ringer stopped ringing. Onl;y way I can tell someone is on the phone is to see it flASH on. There is a place on the handset that sets the ringer to high (#) but it doesn't work and I do not have manuel. Reception is also bad. New batteries installed. I think you set it on the station but I can't find out how. Thank you.
  • 4 more comments
  • Beaverva Dec 10, 2008
    The ringer stopped ringing. Only way I can tell someone is on the phone is to see it flASH on. There is a place on the handset that sets the ringer to high (#) but it doesn't work and I do not have manual.
  • Anonymous Dec 11, 2008
    none of my handsets will ring. only way to tell if phone is ringing is to see call on caller id screen
    ringer does not work
  • Bobs123 Dec 17, 2008
    I have the same problem, the base phone plus i have 1 cordless plugged in, they stopped ringing, i have tried and added a fax machine and this one also is not ringing.
    Please help.
    Thanks,
  • jessie boo Jan 06, 2009
    how can i fix the problm with my ringer on my phone
  • Jackson577 Jan 14, 2009
    same as above
    RINGER WON'T WORK CAN ONLY TELL CALLS ARE COMING THROUGH WHEN IT LIGHTS UP.
My ringer on my phones are not working how can i fix it?
Posted on Jan 06, 2009
Panosonic phones will not ring. I can call out but ringer does not work when someone calls me
mY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Dec 06, 2012 | Panasonic KXTGA410M 19 GHz Cordless...
Where is the ringer button on my cordless phone
The phone must have a ringer ON/OFF switch. ... the phone begins to make the ringing sound, repeatedly press the Volume Down button until "RINGER VOL: OFF" is displayed
Jun 25, 2010 | GE 25952EE1 Cordless Phone
My philips cd135 cordless does not ring when recieving in coming calls what is the solution.
Your phone is prob on Ringer Off mode. Press menu and then scroll down to Personal Set, press menu and Handset Tone will appear on display, press menu and Ring Volume will appear on display, press menu and then scroll to select volume, low, med or high. Do not select ringer off.
Jan 02, 2010 | GE Cordless Phone & Answering Machine...
Phone ringer
The box underneath the setup in the manual (mine's on page 13) describes what TOLL does. It can answer on the 3rd ring, the 5th ring, or if you have messages it will answer on the 3rd ring and not until the 5th ring if you don't.
You can hang up after 3 rings if the machine doesn't answer, because you have no messages. Other manufacturers call it TOLL SAVER.
Carl
Jan 12, 2009 | GE 27959GE6 Cordless Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Need ringer turned back on .. radio shack 5.8GHz
Hit the up or down arrow keys several times. (either key will work) and the ringer will rotate through Ringer off - Ringer low - Ringer high... one set will be a steady ring, the other set will be a warble ring. This works on the phone made for RadioShack with 5.8 GHz on the front and Cat. No. 43-155 under the battery in the battery compartment.
Dec 09, 2008 | Radio Shack 433575 Cordless Phone
Phone not ringing?
go to settings then phone settings then voice commands then call alert and put ring only
Nov 01, 2008 | LG VOYAGER VX10000 Cellular Phone
It doesn't ring
I had the same problem. If the phone is plugged into an outlet with any other device, the phone may stop ringing until you plug into an electrical outlet where it is the ONLY device using that outlet. This has worked for me
Dec 30, 2007 | GE 28112EE2 Cordless Phone
GE dECT 6.0 Cordless Model 28112 Series
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
Dec 08, 2007 | GE 28112EE2 Cordless Phone
When someone calls the buttons flash but doesn't ring.
Your ringer has been switched off..to solve this press the menu button(mute in most of the sets)and press it until you see the option ringer press + to change it to off and then press menu again until you see the main screen...Thats all..
Let me know if it worked..
Oct 20, 2007 | GE 28111 Cordless Phone
Uniden Cordless Phone Logo
293 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
