Cannot connect to wifi from bt home hub any suggestions. laptop higrade 8615gtx
    Scholar:
  • 86 Answers
Could be a variety of reasons.
Assuming you have not had it working before
Assuming the wifi is broadcasting it SSID
Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R
type cmd and enter
type ipconfig and enter
note lower set of figures ie 192.168.0.1
open browser and type in those figures and enter
should now open router firmware
When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
Posted on Dec 10, 2008
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
What connection symbol should i see when my bt hub 5 is wired connected to the internet as it looks like a wifi symbol
The power light should be a steady blue.
This symbol indicates internet connection status and should also be blue.
Feb 12, 2015 | Internet Computers & Internet
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
Can I connect my HP PSC1510 to my BT Homehub v1?
yes, you can. I have my printer connect to my hub and my desktop and I can print from my laptop wirelessly.
You will need your all in one connected via a printer or USB cable to a computer AND also connected to your hub. Then, go to the computer that is connected through a cable to the all in one. Your all in one should have some way to configure its IP address. I have my printer configured as 192.168.1.4 and it's plugged into the 4th port of my hub. Check if this works.
Mar 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
Iphone 3G-S will not connnect to BT Home Hub 2.0
First, Can your 3GS connect on ant other Wi-Fi? If so the issue is specific to configuration on either iPhone or BT Home Hub.
Second, Does BT Home Hub configured for any kind of mac-address security? Check that, if it does either remove it or add the iphone mac-address, you can find the iphone mac address under network setting.
Third, Does Home Hub have limit on number of devices that can connect to it, some do. check that and make sure that you increase the limit or just remove the restriction altogether.
Fourth, IS BT Home Hub Wep enabled? If so the password/key you are entring on your iPhone must be exactlythe same. Or just remove the wep encryption to see if your iphone 3GS can connect.
Fifth, If your old 3G is able to connect to your BT Home Hub, then just make sure you are not FAT fingering the keys and entering a different key.
Aug 06, 2009 | Apple iPhone 3GS Black (16 GB)
Wifi connection to BT Home Hub problems
Make sure you do not have any third party software running in your taskbar that deals with wifi connection if your trying to use the windows connection. this is what i do. its better, and more simple. Home Hub does not work well with non BT software. If your not sure, turn any wifi connection software off. i.e if any came with your wifi device. and then click on the start button. and click connect to on the right lower side of the start menu. You can use almost any wifi device with these devices. your best bet would be to let windows try to connect to your home hub. Also are you typing in your WEP key. correctly. How far away from the hub is the wifi device. Is windows wireless zero configuration off in system services. unliekly. but worth a look. I have had a home hub for three years and i have to admit they are a nuisence. The BT Voyager wifi works ver well. just in case there is some kind of incompatibility with your device, i highly doubt it though. Good Luck.
Apr 27, 2009 | Archos 705 WiFi Digital Media Player
Wifi with itouch
Go to settings, choose Wi-Fi, choose your bt hub from the list, its there where you enter the bt password. It'll automatically connect from then on.
Dec 29, 2008 | Apple iPod touch
Cannot connect to wifi on our bt home hub
Now:
type cmd and enter
Dec 10, 2008 | Computers & Internet
Computers & Internet Logo
400 people viewed this question
David Payne
David Payne
