Question about Toshiba Computers & Internet
Laptop screen suddenly turns white display
I have this Toshiba laptop thats turn in white, don't know why. What have been the problem. pls help
  • Anonymous Jan 24, 2009
    I have the same problem. Laptop works on external monitor
  • Kevin Nelson May 11, 2010
    It sounds like your inverter is going bad. Have you connected to an external monitor?
Toshibas have a HORRIBLE HORRIBLE HORRIBLE overheating problem. In your case, it sounds like the video card is overheating. Use compressed air in a can to blow dust out from inside your laptop. Then lift it up off your desk by propping it with something small, or buy a notebook cooler base. the problem should go away. I'm surprised you haven't experienced auto-shut-off yet.
Posted on Dec 11, 2008
I don't know the password for Terrorist takedown 1.
If you do not have the factory password you are not going to play game, that is why it has a password required !
Jan 26, 2013 | Microsoft Computers & Internet
The screen my laptop is white like white bord
If the laptop's screen is white, try connecting it to an external monitor (at work or at a friends if you don't have one) and see if the output is normal on an external monitor.
If external output (to a monitor) is normal, then in all likelihood, you have a bad screen.
If external output is problematic (like the laptop's LCD), then in all likelihood, the motherboard is bad.
Without knowing what model your computer is, that'd be how I'd go about trying to nail down where the problem is coming from.
Sep 08, 2011 | Toshiba Computers & Internet
I don't know where I got to register my new Toshibs netbook NB505-NB508-BL. Pls advise.
You can register your new Toshiba netbook here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=ProdReg
Jun 03, 2011 | Toshiba Computers & Internet
Toshiba SatelliteA70 over heating, automatically switch off, white screen problem, after a couple times it got automatic switch off, its getting blue screen error, saying that memory dumping, finally it...
DUE TO THE HOT SUMMER SOME LAPTOPS GET TOO HEATED , SO PLS USE A COOLING PAD UNDER YOUR LAPTOP. OR FOR INSTANT SOLUTION KEEP THE LAPTOP IN SLANTING POSITION SO THAT THERE IS ENOUGH SPACE FOR AIR TO CIRCULATE UNDER IT.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Toshiba Satellite A70-S249 Notebook
Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
My toshiba satellite a60 keeps shutting down after 1 minute or less. i cleaned it recently, the coolers are working fine i don;t know what the problem is. pls help urgently!
HI there if you clean the internal system then i suggest you remove the ram & cooling fan & fix it back properly. Another thing is watch the keypad and try to found is there any key pressed or not. I hope you will found the error & solve the problem. Thanks.
Mar 24, 2010 | Toshiba Satellite A60 Notebook
How to start up my computer
take out the battery and put it back in and the manually turn on your pc
May 28, 2009 | Toshiba Satellite A300-0CF035 Notebook
Screen turns white
Hi there.
The ribbon cable which runs behind the screen has either become loose or has become defective.
If you still have warranty on the laptop send it in for repair, if you don't post back and i will tell you how to disassemble the screen to get to the ribbon cable.
If the ribbon cable is faulty you can of course use an external monitor so you can still use the laptop.
Good luck and thanks for using FixYa!!
May 26, 2009 | Toshiba Satellite L305-S5875 Notebook
Cannot install second disk of the vista premium recovery set that was installed by the toshiba manf. i can install other os vista basic/winxp pro i was informed by toshiba tech support previous to this...
they are telling u wrong thing how can it be ram if u are able to load other vista basic /xp ram doent know which OS u are loading this is un acceptable
try this to restore ur OS without disk if ur OS came pre loaded with ur machine
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
pls tell me the results if it helps or not and pls rate me FIXYA if u like
Mar 01, 2009 | Toshiba Satellite A205-S4617 Notebook
Help pls
only way you can reset bios password is to reset the BIOS . to do this
*if its an desktop
open tower , inside the tower you'll see motherboard
look out for battert (wich is size of nickle)
remove the battery and wait fo few second
then insert it back
reboot................
*if its an laptop , let me know model no and make
Feb 22, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
382 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
