Question about Sharp 56DR650 56" Rear Projection HDTV
56" sharp 56dr650 rear projection tv
My tv won't show anything on the screen. power light flashes three greens then two reds. Lamp light flashes red. Manual says lamp failure. I replaced the lamp and it still does the exact same thing. I cleaned the color wheel and know it is good. All the fans come on. Still no picture but tv turns on see lamp light come on then five seconds later it turns off as if the tv is shutting down and then restarting again. What is the problem?
Bill
  • evonborstel Jan 04, 2009
    Exact same problem (flashes 3 green, 2 red, TV won't turn on). Replaced the lamp 6 months ago. Any ideas out there???
  • geek2345 May 07, 2009
    I have just replaced my lamp today and I still get the same light codes and can figure out what is wrong.
Hi - wanted to let you know that I have the same problem and I contacted Sharp (800) 237-4277. They offered me a prorated exchange. Select #1 prompt for Operations and then they will create a case number if you don't already have one and then send you over to the Disbatch Dept. They are picking up my 56" TV and are selling me a LC52"D65U for under $450 current retail value of the new TV $1900. Give them a call and see if they can work out a deal for you too. The whole transaction will take 7 - 10 days. Good Luck!
Posted on Jan 30, 2009
When tv comes on it says replace lamp and reset timer i replaced the lamp but how do i reset the timer have a 56;; sharp rear projection tv
unplug your tv and hold the power button for ten seconds then plug it back in if that doesnt work leave it plugged in and then hold the power button for ten seconds.
Jan 13, 2011 | Sharp 56DR650 56" Rear Projection HDTV
Look my problem is that i have a sharp 56dr650 i replaced the lam p and it worked for 3 days then i turned it back on and nothing happems. No backlight not sound no nothing. The power light comes on...
within the 3 days of replacing your lamp to when it stopped working, did you open the access panel for the lamp again? If you did, the interlock switch might not have engaged when you put the panel back on. Make sure the switch is in the O position, then try powering it up.
Nov 05, 2010 | Sharp 56DR650 56" Rear Projection HDTV
Need a lamp bulb for Sharp 65 inch tv
You could buy it from :-
http://www.purelandsupply.com/56DR650-Bulb-Sharp-TV-Replacement-Bulb.html
Good Luck!!
Thanks!!
Aug 17, 2010 | Sharp 56DR650 56" Rear Projection HDTV
Upon powering up TV the green light comes on and within a second or two the red light comes on and intermitintly flashes, The tv never comes on?
The lamp or the ballast may be faulty. You'll need to replace the lamp first if this is a DLP. That's the cheapest solution. You can buy a lamp for your TV from discount-merchant.com.
Feb 04, 2010 | Sharp 56DR650 56" Rear Projection HDTV
The tv will not come on . The power led is blinking 3 greens and then 2 reds. I have changed the light but still can not get the tv to do anything. I can't even shut the power off with the buttons.
Most likely its not the lamp thats bad but the color wheel is stuck. Check if the color wheel starts or not. You can make this out from the typical dlp switching on whine. If you have already changed the lamp, and there is no color wheel start noise, you have a bad color wheel.
Aug 28, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Tv swithches off and on.
You have a lamp failure. Replace the lamp. Reset the system ( On the remote hold the "menu" and "volume" buttons down until the system screen appears) and you should be ok assuming that the power circuits for the lamp are ok.
Aug 24, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sharp DLP No picture
i have a 56DR650 and it does them same thing. It is still under warranty but where i bought it, they said they can no longer fix it so they are giving my money back. the problem has to do with the color wheel inside.
Oct 31, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 56" Rear Projection HDTV Logo
632 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
