Question about Logitech Z-5300 Computer Speakers
My subwoofer for my Logeitech Z-5300e THX 5.1 Surround Speakers omits a loud hum whenever the system is activated. How can I get rid of this?
    Scholar:
  • 61 Answers
The sound you are discribing is indicative of a short in the audio cable coming from your amp to the woofer. it doesn't mean that you have to replace a cable, but it could mean that one is loose. I would first try to turn on the unit and then start unpluging each speaker from the back one at a time. If the sound stops then you know that the hum is caused by the last speaker cable you pulled out. It is possible that you could make a temporary fix by twisting the cable back and forth where it connects into the back of each speaker. (Though this would only be a temp fix.) Because these cables are hard soldierd into the the actual speaker, there is no way for a person to simply replace the problem cable.
The other possible problem could be with the cables coming from the computer. You might simply have the cables in the wrong inputs. They should be color coordinated. Yellow in yellow, etc. Or with the system on, unplug these cables one at a time to find the problem cable.
If non of these work, I would bring it back to the store for a replacement system if still under warranty.
Posted on Dec 12, 2008
I shocked the stereo jack for my 5300e when i was going to plug it in after taking off my coat. it made a loud noise over the speakers and now the left front and rear channels only very very faintly play...
you have probably damaged the amp chip. inside the radio on the back wall there is a chip with around 10 pins on it that chip is the amp it controls the volume and the left right and front and back, that part will need replacing.
Jul 16, 2017 | Logitech Z-5300e Surround Sound System...
I can't find my manual and need to know where i plug the peach, green & black jacks into
Black means rear speaker, green means front speaker, orange means subwoofer
Hope this helps
Mar 20, 2010 | Logitech Z-5300e Surround Sound System...
My home theater speakers make a constant hum whenever my receiver is on. The loudness of the hum changes with the volume control, and goes away entirely when the system is muted. All components are plugged...
jd40,
Sounds like a grounding issue. The first two places to look into is the powered subwoofer and antenna. During your last test, did you leave the FM antenna and subwoofer connected? Many times the hum is directly related to the antenna and/or the subwoofer and to how they are grounded; creating a ground loop through the receivers ground on the outlet. If the antenna is grounded to the dwellings wiring, hum is inevitable and sometime you can get a ground loop hum from how or how & where the subwoofer is grounded. Try taking them completely out of the loop.
Also try taking it further back to the basics, start with the receiver plugged into a known good grounded outlet with no surge or line conditioner in the loop and nothing connected to the receiver, nothing. Use one speaker and different wire to test each speaker output while in tuner and any other mode but phono. With no signal, you will either get nothing (no hum or static) or just static in the tuner mode. No hum is a good sign. Some systems will mute the speakers if no signal is connected to eliminate the static from being produced through the speakers but a ground loop hum will most likely still be produced even in mute. If you get a hum when nothing is connected to the receiver, try looking into getting a better grounded outlet, even maybe to a different dwelling.
-Chris
Jan 30, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
Loud hHum from Subwoofer
Sounds like the hum might be mains hum caused by the failure of the power supply capacitor(s) in the sub. It/they will be the largest on the pc board. You will find all the details (needed to replace it) on them. If you find more than one replace both.
Dec 10, 2009 | Audio Players & Recorders
Only 2 of my speakers are working on my x530 surround speakers
you need a five channel sound card.
then all speakers will work.
dont forget to vote
Sep 14, 2009 | Logitech Z-5300e Surround Sound System...
I need to hook up this system to my tv.... thanks
you want to install your TV sound thru this Surround sound system ?? let me know
Apr 22, 2008 | Logitech Z-5300e Surround Sound System...
Surround wont work
try and download sound softwares from majorgeeks.com.
hope this works.
Jan 05, 2008 | Altec Lansing VS3251 Speaker
Z5300e Subwoofer Problem.
in my view, it is due to any of the following
1. its fuse burnout or wire breaked, check fuse and cordwire
2. its subwoofer coil is damaged to loud volume, replace it
3. its amplifier IC is damaged, replace IC
Dec 31, 2007 | Logitech Z-5300 Computer Speakers
Logitech Z-5300 Computer Speakers Logo
174 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
