Question about Dell Inspiron 6000 Notebook
Dell inspirion6000 i load up windows xp now the screen goin black
  • aflood Jan 25, 2009
    same
    Scholar:
  • 86 Answers
Restart the PC and as soon as it starts up after the Post Beep and the Bios, press F8 key at the top of your keyboard a few times and you will see a Safe Mode Menu... Your problem is that you are either using the wrong Graphics Driver, or your resolution is not supported by your monitor. You need to go to Device Manager and uninstall the graphics driver and reinstall it... If you don't know which driver to install use Unknown Devices which is an app that will tell you your Unknown Hardware Devices, you can find a good clean version to download at Major Geeks. Google...
Posted on Dec 10, 2008
Screen goes black after loading windows xp
Is it possible that it's display output is set to external screen, display no 2 from within the graphic cards settings/preferences. I cannot see how while in the GUI (XP Loaded) that making an adjustment not suitable for Laptops screen can take affect without XP sending out error messages. I really am curious now as to what the problem is or was, cheers.
May 01, 2013 | Dell Inspiron 2200 Notebook
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Windows XP Home Boots midway and screen go black.
Follow the tips below to fix the problem:
  • Scan PC for Viruses
  • Clean Registry
  • Run Last Known Good Configuration
  • Repair Windows
Mostly professionals recommend Intel Partner Software, RegInOut System Utilities to fix the Windows boots to black screen problem.
Dec 27, 2011 | Microsoft Windows XP Home Edition
Dell computor message on a black screen windows root \system 32\hal.dill what do I do
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
May 16, 2011 | Dell Microsoft Windows XP Home Edition
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
Black screen
That means the Windows "Shell" or Explorer.exe is failing to load. You will have to wipe and reinstall your windows. If you have important data, I suggest you take your machine to a pc shop and have them attempt data recovery.
Dec 13, 2009 | Dell Inspiron 6400 Notebook
I have a dell inspiron 6400 and im getting a black screen once the dell logo comes up and windows xp loads...I see no icons or nothing..just a black screen
it sounds like your display backlight has gone bad. If your handy you can get a new display. If you are really good you can replace the back light.
Nov 07, 2009 | Dell Inspiron 6400 Notebook
Error loading operating system in dell
You may be right , the harddrive on the system may have gone bad.
You can run a diagnostics on the hardrive,shut down the computer, and then Press the Fn+ power button at the same time , it would initate the diagnostics.
Do post the results back
Thanks
proton
Apr 05, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
Blank Black Screen After Windows XP Loading Page
the easiest solution would be to re-install windows and hope it is not a hardware problem
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
Dell inspiron
Try booting into safe mode by continually pressing the F8 key while the system is starting up..this should allow you to get into windows where you can try to reinstall your drivers. Most likely this is a driver issue with the video card or your refresh rate or display resolution is set too high.
Please rate this answer!
Dec 10, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
46 people viewed this question
Alun Cox
