Question about Canon PowerShot A540 Digital Camera
Conecting thr camera to my computer
Hi, when I conect the camera to the compuer by usb, I get this massage : " the device is not recognized". i am using microsoft XP. thanks, keren.
  • starr4u Dec 31, 2007
    Mine does almost the same thing, but does nothing at all.
    Genius:
  • 1,269 Answers
@keren:
That error message somehow means your USB connector wasn't plugged in properly to the camera. Another thing is that windows xp doesn't have driver for your camera that's why it wasn't recognized. what's the brand of your camera though? If you just want to transfer your pix from camera to pc or vice versa, use a card reader like the guy above me said.
Posted on May 05, 2008
  • 30 Answers
To view the pictures on the computer, remove the card from the battery compartment and put it in a card reader connected to your computer.
Posted on Mar 25, 2008
SOURCE:
I have a HD5000 that was working till yesterday properly. now i receive the massage in skype that no webcam is connected. also in the HD5000-application itself i have the same massage. who had the same...
I'm assuming that you have tried a different USB socked with the same result. This has nothing to do with the software, it's a hardware fault. You can check that simply by booting from a Linux Live-Cd and see if the webcam is recognized. Most likely it has just failed.
This is unfixable, you will have to buy a new one.
Aug 14, 2011 | Microsoft LifeCam HD5000 Webcam
Sony Cyber-shot 1.3 Mega Pixel
Try out all these options one by one t fix your problem:
1)just try to unplug the device and have it connected into another PC (with USB port) and let it be recognized by that PC... when it is recognized, plug it again to the original PC it was previously plugged. i know it doesn't make sense but i believe there are some electrical factors that may cause this malfunction.
Another way is... just leave it UNPLUG for half a day or a whole day, and plug it again... probably it will recognize the device itself.
2)install the mainboard drivers of USB so that it can run USB 2.0 devices..........that's it..........
3)Backup your important data in the system partiotion. Then format it and reinstall windows XP fresh copy
4)Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying icon_smile.png.
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Goodluck,
Please don't forget to rate the solution as fixya..
Apr 06, 2008 | Cameras
After conecting to my computer there is no recocnition of camera on computer, time and date were added before conecting to computer will this make a difference to conection does this affect the internal...
Setting the Date and Time manually does not influence the behaviour of the camera. However, if the camera is not 'recognized' by the computer: Check if the USB cable is properly fitted in the camera. Put the other end in a different computer USB port. The computer should see the camera as a Removeable USB Device. If the problem persists, connect the camera to another computer and see if it is recognized.
Jan 18, 2011 | Olympus SP800UZ Digital Camera
I have a konica Monota model DG-5D camera and the USB port is not recognized when I connect it to my PC. I am attempting to down load my pictures to computer and the massage reported from the PC is...
I could not find a Konica Minolta Model DG-5D camera listed on the support web pages.
I did find a "DYNAX5D/Maxxum5D" that had driver software for Windows 98/98se.
If you're using XP or later, these drivers probably won't help you though.
Can you confirm the model number?
Dec 30, 2010 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Hi Running WIN XP (32bit) Have just replaced the Motherboard with an ASUS P5E3 Upon boot up, Windows XP dooes not recognise the USB mouse. The mouse is plugged directly into the MoBO's USB port. I...
Method 1: Initiate recognition of the USB device by using Device Manager----To initiate recognition of the USB device by using Device Manager, follow these steps:---
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Managerwindow opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  4. Close the Device Manager window.
If this method resolves the issue, you are finished.
If this method does not resolve the issue, go to method 2. Method 2: Disable power management of the USB hub---Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:===
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
  8. Close the Device Manager window.--
If this method does not resolve the issue, go to method 3--- Method 3: Restart the computer---To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site:---- http://support.microsoft.com/contactus
--- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 02, 2010 | ASUS P5E3 Deluxe Motherboard - Intel X38,...
USB Device not Recognized
The camera should have come with software which includes the correct drivers. Did you install the drivers before connecting the camera? The camera simply may not be compatible with your OS.
Sep 05, 2009 | Microsoft Windows XP Home Edition
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Maxtor and vista
Try some other USB device (memory-stick, printer, camera) in the USB slot in the Vista computer, just to "prove" that Vista will recognize _any_ USB device connected to that slot.
May 31, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
USB device not recognized on my VP-D371i Samsung digital camera
i am also have Samsung VP-D371i if u need help my icq number is 400 952 967, but my Samsung VP-D371i do not support usb iam use other line
Feb 23, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Canon PowerShot A540 Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
