Question about Oregon Cutting Systems Oregon Grease Gun
Broken grease gun
I have had your oregon grease gun for about a month, dropped it on the floor and it broke! Seems like it would have been more durable.
    President:
  • 2,220 Answers
Please file your complaint Here:
Customer Service:
OREGON®
(503) 653-4706
(800) 223-5168
technicalservices3@oregonchain.com
Lou
Posted on Sep 05, 2009
Can I remove the ball check on front side of my gun, I have and seems like it won't push grease
The short answer is no! The check ball plays an important role in the proper operation of the grease gun. What prompted you to remove the check ball in the first place? If you have grease coming out of the relief valve you have a different problem entirely. If this is the case just let me know and I can guide you through it!
Apr 14, 2015 | Lincoln Industrial PowerLuber 18 Volt...
How to load grease in it?
The model 1056S will accept the standard grease cartridge available at any parts store. I have to use a razor blade and cut off the metal pull tab end. Then push the cartridge into the cylinder from the top. The real trick is to guide the rubber seal into the cartridge; it can be done, I load mine this way. Use the little lock to hold off the long plunger, allow just enough to work with inorder to insert rubber seal into cartridge. Only after the rubber is in the cartridge, then screw on the bottom cap. Then release the long plunger rod. You noticed that the plunger rod will rotate out of the rubber seal assembly, rotate it so the rod can be pushed into the cylinder without pushing the rubber seals. The sping will push the rubber seal to ensure grease is mover to the top. Very powerful PSI, do not blow out the rubber cups around the zerk fittings. Good luck
Jul 05, 2014 | Alemite Lever Gun Model 1056s
Quantum XL-1000 won't embroidery
I would email Singer's Customer Support and demand a complete replacement. http://www.singerco.com/support
Your repair person dropped the ball and this isn't getting better.
The squeeky wheel gets the grease. Bill in Oregon
Mar 21, 2014 | Singer Quantum XL-1000 Computerized Sewing...
Ingerroll rand 2132g how do I oil my air impact wrench?
Most I.R. impacts require grease in the hammer mechanism (clutch) and oil in the air motor.
To lubricate the air motor simply add oil through the air inlet about 3 to 6 drops at every use.
To lubricate the hammer (clutch) mechanism you will need a grease gun with a needle, the grease fitting (item# 17) is located on the hammer case assembly (item# 15) 2 or 3 small squirts will sufficiently lube the hammer (clutch) mechanism.
With heavy use grease the tool once a month, with light use 2 to 3 times a year.
Follow this link for the parts list, also indicates the grease needed:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/80164726_ed4.pdf
Aug 04, 2013 | Impact Husky® 1/2" Wrench
Is there a specific type of grease gun ad grease I
There is really no special grease gun to get. Any type of grease gun will work. I personally use a high temp. grease at the shop I work at. When greasing anything never over grease a joint , it causes a mess and will cause premature failure. All that is needed is three pumps of the grease gun.
Aug 16, 2009 | 1993 Lincoln Town Car
REMOVE PARKING BRAKE ENGINE STALLS
i have a cub cadet 2130 2000 seris but it quits when i rekwase the brake pedal
May 03, 2009 | Oregon Scientific Oregon Gator Mulcher...
Craftsman 1/2' impact gun
Use a good grease. Don't pack it, just lube the parts. If it is all together, put in about half an ounce of air tool oil through the plug.
Apr 15, 2009 | Air Tools & Compressors
How to heat gun
When you remove old carpet from a room, you will most likely be left with remnants of glued-down backing on the floor. Getting the tile back to it's original smooth appearance can be a tedious task. You will need to make sure that you have a lot of patience and a lot of elbow grease. Start removing the glue by scraping the tile with a heavy-duty wallpaper scraper or a long-handled scraper. Do a quick sweep of the floor. Plug in your heat gun. Once it is heated up, you will want to place it at a forty-five degree angle to the floor and direct the heat on the remaining carpet backing. The carpet backing will loosen considerably as the glue begins to dissolve. The carpet backing will loosen considerably as the glue begins to dissolve. Use the wallpaper scraper to remove the loosened backing. Work in small sections. Once you have removed the carpet backing from the tile, wash the area with warm water and soap to ensure all of the glue and backing are removed. Continue until the entire tile floor is free of carpet backing.
Aug 27, 2008 | B O X Packaging Two Temperature Heat Gun
Oregon Cutting Systems Oregon Grease Gun  Logo
155 people viewed this question
Top Oregon Cutting Systems Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Oregon Cutting Systems Garden Expert? Answer questions, earn points and help others
