Question about Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier
Shutdown when i turn the amp on it works for about 5 minuets and then it cuts in and out for a while and then it stops altogether
    President:
  • 2,992 Answers
There is either a thermal problem in the amp itself (a bad part) causing it to shut down after a while, or the amp is overheating due to a load problem. This may be due to wiring issues or a bad speaker. Try running the amp into a set of test speakers connected directly to the outputs with all the other speaker wiring disconnected. If the amp still shuts down you'll know the problem is in the amp itself. If it runs OK, you'll have isolated the trouble to the wiring or speakers and can test that portion.
Posted on Dec 10, 2008
I tried to sign in and it said I used the wrong info. I used the same I always use
Hi, Try turning your router off & back on again then wait a few minuets say 5 & everything should be okay then. Remember it pays to do this from time to time. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 03, 2017 | The Computers & Internet
General lee cb gets hot and stops transmitting and receiving.
Connex general lee - Mauldroppers CB Radio Forum
www.mauldroppers.com > Citizens Band Radio > Mobile DiscussionOct 23, 2012 - 13 posts - ‎7 authors Thread: Connex general lee ... amps and is getting cookin' hot when key'd for as little as 30 seconds, lol, truckstop hack job comes to mind lol.
Oct 02, 2015 | Radio Communications
How can I stop the beeping noise when going in reverse
Find the buzzer and disconnect wires from there, or cut one or both of the wires at the buzzer and tape the connection to prevent shorting.
Apr 01, 2015 | Pride Mobility Products GoGo Elite...
It runs very slowly & the apps aren't responding as they should
Easy turn off all other settings cut it off wait 3 minuets then try it it will work
Feb 06, 2014 | Visual Land Prestige 7" Tablet Purple -...
Compressor tries to start, making a humming noise then cuts out
then it is time to replace it if actually needed. fixing old ones is usually not cost effective anymore
Nov 17, 2017 | Freezers
I have a Technics ammplfier SU-V4X after playing for about 5 mins it cuts out , it gets over heated . what can I do to stop this.does it have a fuse I can remove
you will have to cleac dust or debris from fan exhaust and filter, can cause it to go into shutdown. Amps will do this to protect them from damage. Regards, meder's tv service
Oct 01, 2011 | Technics SUV500 2-Channel Amplifier
Dometic Refrigerator Model RM 2820 Stopped working purchased 5-4-2004 . Tom Collins
Hi Tom,
If your fridge quit working altogether, check your DC fuses in the fuse box, as well as the back of the fridge under the black plastic cover (3 amp). Though the fridge uses LP and 120vac to cool, it is controlled by 12 volts.
Apr 30, 2010 | Dometic RM2620 Refrigerator
Will not run or turn on light will not turn on
Had a similar problem with Goldstar model DH305. A solution was already posted about cutting the two white wire going to humidity control, and it works until tray fills up (no control). However, if you want a complete fix which allows you to control by selecting humidity level go to the following site:
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282871&modelsID=&typeName=dehumidifier
Part number is 6877A30013L
May 27, 2009 | Goldstar DH304 Dehumidifier
Plug any hardware into the usb port, after 5-10 minuets cuts out?
Find usb root hub in device manager, turn off power management.
Apr 23, 2008 | Computers & Internet
Whirlpool gold - american collection - ultimate care 2 model : 3rgse9455jo3 / serial cs1505345 just stopped working altogether
First check for power. need more info as to what proceedures you've taken to make it work.
Apr 03, 2008 | Washing Machines
Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier Logo
119 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
