Question about Maytag Atlantis MDE6400AY Electric Dryer
Dryer not working but the light is on
I have a maytag dryer that has stop running here is what happened and what I have done so far. The dryer got chocolate in it one the the kids, I cleaned it out but there was an electric smell to the dryer after that and then it would not work a few days later, I tripped the breaker turned it back on and the dryer worked again for about two days and then the same thing again, now the breaker trip does not work. The light is on in the drum there is no brun marks near the block or on any of the wiring, I have checked both thermal fuses and the venting system all is good there, the timer does not want to run now either. Is this a power problem or do I need to replace some part of the unit?
  • James Nutting Mar 02, 2007
    The door swith is also working forgot to include that information
  • James Nutting Mar 03, 2007
    I have done that but what about the timer not running it just doesn't work
  • 72 Answers
Add peanut butter for better taste. lol... but seriously, the dryer should be be disassembled somewhat so that all the chocolate (or the residue it left) can be completely cleaned out. Unplug it of course. Get a can of electrical spray cleaner from an auto parts store and squirt off everything electrical inside.
Posted on Mar 03, 2007
How do I fix my cycling dryer.
so you have not done any work on the electrical system at all changed anything or anything like that do you have a model number Appliance 911 Sea Breeze
Nov 15, 2015 | Maytag Dryers
Dryer just stopped working. the light doesn't even come on when door is open. this is a maytag dryer model hye3460ayw.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 06, 2010 | Maytag Dryers
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
May 24, 2009 | Maytag Dryers
Maytag dryer stopped working in middle of cycle
I think that the most likely thing that has happened is that the cord has shorted at the terminal block. Disconnect the power from the wall and then pull the cover off the back of the dryer and I think that you will find the problem there. It will be obvious.
Apr 02, 2009 | Maytag Dryers
Maytag dryer sdg515daww stopped working.
I assume this is Gas dryer from the model number having a G.
The door switch may cause the problem. If its not running the dryer thinks the door is open? And the light will also stay off. You can jump around the wires on the door switch and see if it works then if so its switch time.
I don't think a thermal fuse should have anything to do with the light. But that's not a bad idea for quick trouble shooting if a manufacturer would do it. Use a volt meeter to verify the voltage you may have enough for the timer to make noise but not enough to make it turn and the dryer to run.
If there is power then try rotating the tub slightly. The motor may have stuck. Don't turn it too far unless you know which way the drum turns. and try alkways to turn it that direction. Keeps your belts on.
If this helped you please rate me accordingly and good luck.
Mar 13, 2009 | Maytag MDG2706A Gas Dryer
Maytag dryer quit working
check your braker turn off then back on
Dec 12, 2008 | Dryers
Gas Dryer does not run, light comes on in drum, everything else is dead.
do you mean it doesn't heat or does not run at all. i would check the door switch, if its not running at all. try opening the door and push the door switch closed by hand, if the light doesn't go out replace the switch
Nov 11, 2007 | Maytag MDG7600AW Gas Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
75 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
