Question about Ricoh Aficio 2018D All-In-One Laser Printer
Fax confirmation We are using Ricoh 2018D MFD with Fax option. Whenever I send a fax message, I am getting the confirmation printout which I don't want. Please help me out.
  • Anonymous Mar 13, 2014
    Is it possible to set a Ricoh MP301 to print a fax confirmation ONLY when transmission fails?
You can turn off confirmation report in USER TOOLS/FAX FEATURES/KEY OPERATOR SETTINGS/USER PARAMETERS Each user parameter has a set of switches, and each of the switches consist of eight bits, whose value is 0 or 1. The right most bit is bit 0 and the left most bit is bit 7. Once you are in USER PARAMETERS select switch 3, set bit 0 to 0 and set bit 5 to 0. To toggle between 0 and 1 for bit 0, press the 0 key. To toggle between 0 and 1 for bit 5, press the 5 key. Bit 0 sets the confirmation report for memory TX Bit 5 sets the confirmation report for immediate TX. Robert
Posted on May 14, 2007
  • 3 Answers
Hi TUlsi The majority of fax machines will do this, I know as the ones i use in DHL are the same when i contacted the company Cannon they advised that it could not be disabled. Which give the solution, All faxes are different and you will only know how to disable it by contacting the manufactures support. I agree full it is anti enviromently friendly and a waste of ink
Posted on Mar 09, 2007
  • Teresa Wong
    Teresa Wong Sep 02, 2014
    HOW TO PRINT OUT ALL FAX CONFIRMATION ON RICOH FAX MACHINE?
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Error message -using handset (no handset on the machine. mfd - 1515
If this appear for the first time see the follow, if this started to appear after a time of usage you will need to call a Ricoh technician, sorry but i cannot gain some help in this type of problems.
see do you use a cord with two wires or four for Ricoh when using some telephone centrals like a Panasonic it's better to use a two wired cord for the line, if this still do not help, you will need to call the telephone central technician to set the line for the Ricoh fax.
Nov 17, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Fax confirmation with copy of 1st page
what is the error code 05 for ricoh fax 1140L?
Jul 21, 2009 | Ricoh FAX1180L Laser Fax
Ricoh fax 2050L displays: "Check paper size", and also shifts image or text toward bottom margin by 3 inches or so. Sometimes locks up during printout.
Thru user tools check what size is said to be in the fax and if it has the optional tray that size too. -Carl
Apr 14, 2009 | Ricoh 2050L Laser Fax
Ricoh 2018D
press [user tolls/counter] and then before you press the system features press it and hold the [#] button and while you hold the [#] button press [OK] the copier will ask you do you want to return the setting to default or not.
This procedure you may make and for the fax setting and for the printer settings.
After this the machine will bring the settings to the default
Feb 23, 2009 | Ricoh Office Equipment & Supplies
Wrong Settings on Ricoh 2018d Nashua
1.Press [user tools/counter] key .
2.Press and hold it pressed [#] key.
3.While you hold down pressed the [#] key press [OK] than the copier will ask you do you like to return the settings to default or not.
This procedure you will have to repeat to all the features.
example : [system features] or [fax features]
remember while on the display writes [fax features] you should hold it pressed the [#] key and while is pressed he [#] key press the [OK] key ones .
Feb 20, 2009 | Ricoh Office Equipment & Supplies
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fax Confirmation Sheet
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Confirmation Printout
Yes go into reports on the operation menu. use the arrows to get where you want and confirm by hitting set.
Nov 13, 2007 | Brother IntelliFax-4100e Fax
Ricoh Aficio 2018D All-In-One Laser Printer Logo
1,158 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
