Question about GE WSXH208A Front Load Washer
The door latch will not realease on the GE WSXh208 washer
I replaced the door latch with the replacement part from GE closed the door and the 'alarm' sounded stating the door was not closed when I attempted to open and reclose the door lock/release would not release. the lock light is off but still will not open- as I tried to pull the door it started to separate so I stopped. I cannot locate any schematics online to assist in opening the unit to try and fogure out how to release the door. The door will not unlock. The wash cycle completely finished and the light is off, but the door will not unlock. I tried finishing the load in different cycles, and it still will not unlock. I tried unplugging it for several hours, still locked. We pried it open with a screwdriver to get the clothes out, now the door will not close. Our guess, it is still in the locked position so won't let the door close.
Called a few repairmen, some say door lock assembly, some say circuit board. Washer is 9 yrs old. Don't they last longer anymore?
  • 14 Answers
SOURCE: washer will not stop spinnig
You probably have a blocked pump. Pull it out and clear the obstructions- buttons, lint, etc
Posted on Sep 11, 2007
  • 1294 Answers
SOURCE: washer load became imbalanced and forced door open, now cannot close door, lock stuck and washer will not run
Perhaps you have to change your lock, this is a sensitive point & will affect the smooth operation of your machine. Re. the inbalance, you hv to screw up & lock the front 2 legs (with check nut), adjust the front legs (screwed up) only to see if the machine does not move during wash/spin.
Posted on Nov 29, 2007
tierraturf
SOURCE: Won't turn back on and finish cycle
I had the same problem with my washer. Ended up buying a new water discharge pump. Fixed the problem right away. Pump was $137.00 shipped to my house. Installs very easy... 2 Screws... Pull the cover plate at bottom of washer.. The pump is attached to the housing of the drain clean out. If you look in the right hand corner of the bottom of washer you will see it. It is white... Try to cycle your washer. Pull the electricity plug... Make sure no power. Take your hand and put on top of pump motor. My was very hot.... If so, chances are you have a bad motor. You will have to replace the whole assembly... This is a result of keeping the drain clean...
Posted on Jun 04, 2008
dutchman05
  • 487 Answers
SOURCE: door won't lock and washer won't start
means your doorlock is either not alligned any more or you need a new door lock. Not overly easy to put in but it can be done.
Door latch can be obtained here and drawing is HERE
Posted on Jun 24, 2008
appldoctom
  • 311 Answers
SOURCE: GE Front Load Washer WSXH208HIWW Door Won't unlock
more info/unplug reset wait 5 min
Posted on Dec 31, 2008
Door ajar alarm stays on after closing door. Some times for hours
Older cars, the switch is in the door jam. Newer cars it's built into the door latch, Even newer cars, they put a sensor in the latch that can be replaced, With out replacing the entire latch.
Feb 20, 2016 | Cars & Trucks
GE washer WSXH208 I shorted out he 2 wires (blue and white) on the bottom of the door latch assembly thinking I could hot wire it to run while the part came in and heard a click in the left side of the...
Probably a relay that you heard clicking. from what you described sounds like it's just a SPST(single pole single throw) switch and nearly impossible to hook up wrong. Good luck!
Oct 11, 2014 | Washing Machines
Driver door closed but door alarm and lock keep going off?
Sounds like the door latch is not closing all the way, Try spraying some WD40 into the latch in the door where it hits the striker post. Hold the door handle up and bump the door shut and open while holding the handle up on the out side several times, This should loosen the latch up and the door should close and latch. The more you spray and work the door the better it should get. If not the latching mechanisim may need replaced. I hope I have help you sovle the alarm problem.
Apr 02, 2013 | 2002 Ford Taurus
Frigidaire washer model ATF6000ES1 door not locking, the door closes, but it's not recognized by control panel.
You are having a problem with the door latch sensor indicating everything is connected correctly. Check to make sure your door is not sagging and then make sure the door latch is not broken or cracked.
Jul 22, 2012 | GE Energy Star WCVH6260F Front Load Washer
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
GE WSXH208 Washer - Filter is CLEAN - Could it be the Control Circuit Board? Live in a condo where many residents have this washer and experienced the same problem. Final spin never kicks in fully...
Hi this either a speed control board which is located in the bottom of the washer, or a bad latch assembly on the front where the door latches into, the board is the more expensive of the 2 but usually the board is the problem. there is not a very easy test for either one, one quick test for the latch is if you start the washer and it locks the door and you let it run 2 mins or so and then turn the washer back off how quickly can you open the door? 10 sec? or like 30-40sec? If its like 5-10secs you have a bad latch. Otherwise i would lean towards a bad board. The board is about 125-150.00.
Sean
Mar 27, 2011 | GE WSXH208A Front Load Washer
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a GE dishwasher model GSD1100G and the door will not latch now. Any ideas?
Yessir, I have a few.
1. Check the latch and strike. Usually, they're just loose.
2. Check the wiring to the switch. The lock and latch take a good bit of vibration being opened and closed.
3. Take a good look at the latch for physical damage. It happens. Your only recourse here is probably to replace the latch.
4. You didn't mention if the washer would run; the door latch is a permissive switch - if the washer will run, the switch is making contact, but the latch is defective. If it won't run, either the latch switch is bad, or the issue may be the control panel.
Best regards, --W/D--
Aug 12, 2009 | GE Dishwashers
GE WSXH208A Front Load Washer Logo
149 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
