Hello,have you tried to hold the button down for 5 seconds? If so the hold in the power freeze and the power cool buttons untill the screen goes blank and then wait. That should reset the controller for you.
Samsung RF267 - water line keeps coming apart at connector between line from refrigerator and line...
(More)
Samsung RF267 - water line keeps coming apart at connector between line from refrigerator and line from cutoff valve.
Help me remove the front door control panel so I can replace the LED. I have removed the sheet...
(More)
Help me remove the front door control panel so I can replace the LED. I have removed the sheet metal screw on the penal bottom next to the dispenser and pried firmly around the perimeter, but the panel will not budge. What am I missing? I do get cubed ice, the light went dim for a few days, then out. Thanks Gil
was cleaning the fridge, door alarm was sounding, but I couldn't close the doors. a couple of...
(More)
was cleaning the fridge, door alarm was sounding, but I couldn't close the doors. a couple of minutes later one light bulb went out, and then a minute later a second one . both light bulbs are okay -- tested them on another lamp. have disconnected the unit, hoping something would reset. no difference.
my fridge isn't cooling at all, but my freezer is working jst fine, what could be the problem? my...
(More)
my fridge isn't cooling at all, but my freezer is working jst fine, what could be the problem? my refrigerator is not cooling, but the freezer is working fine. it is a samsung side by side.
when and if it works only the refrig. side gets cool to@36 degrees then it stops.freezer side...
(More)
when and if it works only the refrig. side gets cool to@36 degrees then it stops.freezer side nothing ,none of the circulating fans go on.compresor seems to be working at low but not high point .checked main board, fuse ok no signs of overheated components .compresor fan works.
