Question about Cameras
I have a x 700
I have a Minolta x 700 from the 80's and need to switch its lens. i am trying to transfer the same kind of locking system from the lens- it is a conon ae-1 lens. for slr. it looks as though i could unscrew the the casing and fit it exactly. ideas?
  • 148 Answers
It may be easier to find a convertor on ebay. It's not always successful as you have to take into account the distance of the real element form the film plane etc.
Posted on Dec 11, 2008
Need to clean my minolta 75-300mm internally
Do you have a lens collimator and other equipment necessary to ensure proper alignment when reassembling the lens? If not, take the lens to a reputable camera shop and have a properly trained and equipped professional do the cleaning.
Mar 10, 2014 | Minolta 28-80 AF Lens
C koi code c0610 de photocopie minolta ep4000
Lens Motor malfunction that is a motor located under the big glass, to reset open front door, up left small access cover remove, press small left switch, if the code comes back then you need a new motor
if some one cleaned the lens system might have damaged the lens motor, try this site for parts Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Nov 15, 2011 | Minolta EP4000/5000 CS/PRO Copier
I recently bought a Minolta X-700 but I have found two problems with it. First, the manual film advance does not work. When I try to advance, it just freely moves to right when it should tug a little and...
Ah, the X700, I used one for years until it just got to the point where it was worn out. As you are aware these cameras are mostly in the 25 year old range and if they have not had proper tune ups and maintenance done it is likely that it has issues, and likely had them when it was sold to you. Your best bet would be to take it to a reputable camera repair shop and have them give you an estimate.
Mar 11, 2011 | Minolta X-700 35mm SLR Camera
Macro problem
Most modern lenses have a lot of plastic to save money and weight. Any trips in a hot car?
May 12, 2010 | Sigma 28-80 F3.55-6 ASP Macro HF (1:2)...
Have multiple Minolta X-700 bodies, the 400mm Minolta MD lens, does lock onto one body but not some of the other camera bodies. Any idea why?
If your other lenses lock on to all of the bodies, then it is quite likely that the notch on the mount edge of the 400mm is worn. The notch is located about 90 degrees clockwise from the red marker dot on the lens barrel. I doubt if there are new replacement mounts for that lens. You may be able to square up the edges of the notch with a small file.
Jan 23, 2010 | Minolta X-700 35mm SLR Camera
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
lightspiritphotography.com
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Instuctions for opteka 650-1300 lens for use on konica minolta
Try turning off the shutter lock.. In my Dynax 7D manual it tells you to turn off shutter lock when attaching to a telescope or microscope this is what this lens basicly is .The shutter lock is turned on and off in section three of the custon menu on my Dynax ,check your manual for your camera to find out where to turn on and off shutter lock, hope this helps
Jan 18, 2009 | Canon Opteka 650-1300mm F8/16 Super...
Lens adapter
No. Unless the lens has a generic T-mount with a Minolta adapter. In that case you can replace the T-mount with a Pentax adapter.
Aug 02, 2008 | Vivitar (218488) Lens
Lens
Sorry, the mounts of Minolta manual focus lenses are different than their auto focus series. Sigma, Tokina and Tamron all make compatible zoom lenses to fit the Maxxum series cameras
Dec 30, 2007 | Minolta Maxxum 400si 35mm SLR Camera
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
