Question about Intimus 602 SC Shredder
The door of my intimus 602 has fallen off, Is there some kind of repair assistance i would be get
Intimus 602. shredder goes about 2 inchs and then goes into reverse and has a flashing red light
Clean the paper shredder teeth and make sure that there is not paper caught in it and try again to shred.
Jun 02, 2017 | Intimus Office Equipment & Supplies
Why does my intimus 602 shredder only run in reverse
This applies if Reverse is forward, and forward is running in reverse. If someone worked on it they may have reversed the wires from the motor to the board. There are four wires from the motor, of the four one goes to MZ on the board, another one goes to MV. If you swap these two wires you will be running in the correct direction again.
Aug 14, 2014 | Intimus 602 SC Shredder
Intimus 602 shredder not shredding
Does it run backwards? If it runes in the right direction, it should take paper. You only should use the reverse, when the machine got stuck. But perhaps it now is running back. Or something broke, so the motor is running, but not driving the mechanical parts inside.
Jul 27, 2014 | Intimus 602 CC Shredder
Pulls paper, stops and shows jam.
You need to excessively lubricate the along the feed opening and let it soak, might need to repeat a few times, then make sure bin is empty and run in reverse for 2-3 minutes it should solve the problem Good luck
Aug 19, 2013 | Intimus 602 SC Shredder
We have an Intimus 502 that displays along with the power green light, the amber light for door open, basket full constantly. jumpered the magnetic door switch and nothing changed. checked basket full...
I have the same problem I am yet to find a solution.
There is a long flat 2cable marked red/white which is connect on the main board the connecting points are short but why that long cable.
Aug 04, 2011 | Intimus 502 Shredder
Intimus 702cc pilot lamp issue
Paul,
Add more oil to the automatic oiler (I'm guessing a Bijur model with a minimum/maximum line.
When it gets close to the minimum it has a feature that will not allow the shredder to run. If this doesn't solve the problem, it probably needs to be reset. I can help you do this too!
Feb 19, 2009 | Intimus 702 SF Super Fine High Security...
DOOR PANEL
Most likely some kind of repair to the door panel will be needed, they should'nt have fallen out, so it is best to remove the panel, it only takes about 5 minutes, worked on 100's of Mustangs like yours, that was an average time.
Oct 13, 2008 | 1998 Ford Mustang
My LG GR-602 TVPF fridge needs the freezer door replacing.
I have been billed for your service when I was told I would not be as your service was of no assistance to me.
Oct 08, 2008 | Refrigerators
Intimus 602 SC Shredder Logo
27 people viewed this question
Top Intimus Office Equipment & Supplies Experts
Lonnie Arks
Lawrence Oravetz
ray gallant
Are you an Intimus Office Equipment and Supply Expert? Answer questions, earn points and help others
