Question about Dell 0E903 Pentium IV 1.4GHz CPU/Processor 0K 400 C1 for Dimension 8100 Computer System series
No display on monitor
When I switch on my computer there is no display. When I remove the D plug that connects between the monitor and the the CPU at the CPU I get a no signal message. On reconnecting I lose display. Seems to be the CPU rather than the monitor.
  • Winslowe Austin Mar 04, 2007
    Thanks, John. Sorted first time.
    Sergeant:
  • 310 Answers
Hi, sounds like a problem with your base unit, might be a lose graphics card, a stick of memory might need taken out and put back in. shouldnt be expensive to fix. as that will give you the fault that you describe with the monitor. as the base unit aint posting, and the signal aint being recieved, if you have basic knowledge you should try taking out the graphics card and refitting it, usually does the job :-) All the best, John
Posted on Mar 02, 2007
My hp 1502 lcd monitor only shows a white screen
If you don't use an identical monitors, then they may not work if your video card can not handle them. The "check video cable" it means the monitor does not get a signal, and it does not mean that the monitor is a problematic monitor. You can test this monitor as a single monitor (and try to connect it using first video port, and then move it to the second video port).
Mar 05, 2014 | HP 1502 LCD Monitor
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
My computer turns on but my screen wont HELP NOW
please check on cables connecting the monitor to your tower/cpu. make sure both ends are plugged in tight. check on the monitor power light aswell, if its blinking or not, if the monitor has been more than 5years old too, its possible thats already dead computers have a life time too especially the old models.
Apr 06, 2011 | Computers & Internet
After turning my computer on, the only thing I get is ''no signal''
This occurs due to the Monitor display cable not connected properly. Please double check the cable from Monitor to the CPU(the main box).
You could also try removing and inserting the cable again.
Please be careful and don't apply excessive pressure as you might break the monitor cable "pins" if inserted wrongly.
This should fix your problem. (Assuming both the CPU and monitor are switched on.)
Feb 03, 2010 | E-Machines eMachines Desktop PC
Monitor will not power on. All of the connections
yes all the connection are intact, in these cases have the cpu check the monitor is not the problem, the monitor is still displaying which means that it is good, have the cpu check or check how many vga adpater is present in the cpu, if you have a built in and a separate card and you plug the monitor to the built it will not work and you need to connect it on the separate expansion card that is install inside your cpu
michael
Nov 20, 2009 | ViewSonic VX2235wm LCD Monitor
Monitor looks as if there is no CPU
If the power supply is coming to CPU before activation of CPU then it must be receiving current from UPS. Don't try unplugging, You may get shock. Thank you, Sir.
Sep 17, 2009 | Computers & Internet
L1932TQ Fails on Desktop, works on Notebook
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
Jul 12, 2009 | LG L1932TQ LCD Monitor
Cpu does not connected to monitor
I am guessing that you see lights on your computer, but no display on your monitor.
Have you tried another monitor? If you have and still no display, try unplugging everything from outside the computer except the monitor and then try again.
If no display, unplug power from computer and open the computer. Remove all expansion cards other than the video card. Disconnect all the cables from all of the drives, then connect power and try again.
Let me know if you need more help.
Honest1abe
Feb 25, 2009 | ASUS P5V800-MX Motherboard
No signal on monitor
I think you need to connect the cpu cable with the monitor to start it.
if still your computer turns on without issue, but your computer screen is showing a No Signal message, it could be due to problems in the CMOS, RAM, VGA card, or the cable that connects your CPU to your monitor.
If the cable is a problem. You can get a new one at
Computer Memory CPU SSD HDD Upgrades for Servers Laptops Desktops
Mar 29, 2017 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
Alun Cox
