Question about Samsung Hue (SCH-r500) Cellular Phone
Alltel Bill question
I was wondering what Daily - Text Msg / N & W means on my Alltel bill? I'm being charged 75 cents per day for this, and I haven't been using the phone at all.
  • 31 Answers
On Alltel U prepaid, you get two free features for 75 cents a day, three for $1.00 a day, and four for $1.25 a day.
The four features offered are unlimited text messaging, unlimited night and weekends (N&W), unlimited mobile to mobile (M2M), and unlimited calls any one number. You decide which ones you want.
The fee is charged every day, regardless of usage or not.
The only way to not get charged every day is to switch to the pay-per-minute plan or get a monthly plan.
Posted on Apr 13, 2009
What is GST in INDIA?
We have no means to answer this question on the far away land of india
Jul 20, 2017 | The Computers & Internet
I have a 3VE53 heater and was wondering about how much eletricity does it use if I keep it at 65-70 degrees for 9 hrs. a day?
Okay, for example a 100 watt bulb left on for 10hrs uses 100x10 =1000. so 1000= 1kwh. so look at the watt rating on the fan motor and times that by 9hrsand then do the math, then look at your bill and see what you pay per kwh (kilowatt per hour) and times that with your answer, for example lets say the heater blower is 10watts, take 10 X 9 = 90, then 90 divided into 1000=.09 so it .09 of a kilo watt almost a tenth of a kilo watt. so if you pay 3.25 a kwh then you would say .06X3.25=.195 less than one cent, hope this helps
Feb 16, 2012 | Dayton 3VE53 Oil Filled Liquid Fuel...
Web and Picture messaging not working.
You need new setting for the picture messaging service.
Most operators use different setting for PAYG and Contray customers because of they billing (PAYG needs to use a different server to check you have credit before sending whilst contract will send then add the charge to your bill)
Jun 15, 2017 | Cell Phones
How to write an electricity bill in c program(9'th class)
#include <iostream.h>
#include <conio.h>
int main()
clrscr();
long int units,charge=0;
float total;
const int rent=25;
cout << "Enter the number of units used : ";
cin>>units;
if(units>200)
charge=(units-200)*20+150*40+50*60;
else if(units>50)
charge=(units-50)*40+50*60;
else
charge=units*60;
total=0.01*charge+rent;
cout << "You have used " << units << " units." << endl;
cout << "Your total telephone bill is $" << total;
getch();
return 0;
Please accept the solution. Thanks, Lucy
This program takes in the number of units used ('units') as a screen input from the user.
It then calculates the total telephone bill for the customer on the following basis :
A compulsory fee of $25, plus
60 cents per unit for the first 50 units,
40 cents per unit for the next 150 units,
20 cents per unit for anything above 200 units.
It then outputs the bill using the 'cout' command.
Jan 12, 2011 | Microsoft Computers & Internet
Hi, Yesterday I bought haier 12000 BTU air
To determine the cost of using this air conditioner, you will need to find out what your electric company charges per kw/h. This is the standard unit that electricity is charged for. Next determine the wattage of the air conditioner. This should be found on the unit name plate. If you can not find the wattage by the name plate, the take the voltage and multiply by the amperage, this will give you watts. Next multiply the wattage by 24. (watts per hour x 24 hours) Finally divide this number by 1000. This will give you the total Kw that the unit will use in a 24 hour period. If you multiply this number by the cost per Kw that will give you the operating cost of your unit for one day.
ex. electric company charges .25/Kw The unit uses 1000 watts 1000 x 24 = 24000 watts 24000/1000 = 24 Kw 24 Kw x .25/Kw = $6.00 day
Note: all figures shown above were randomly generated in my head, and have no correlation to your calculations. Hope this helps.
May 04, 2010 | Heating & Cooling
How much energy dose a 7096 heater use
As far as I can tell, your unit is rated at 1600 watts max. That means it will use 1.6 kWh per hour. Check your electric bill for what they charge for a kilowatt hour but it is usually less than 20 cents. So I would guess less than 30 cents an hour at highest temperature. Hope this helps and please rate my answer if it was helpful.
Dec 30, 2009 | Lakewood Oil-Filled Electric Radiator...
How much electricity does the cooler use each month?
Electricity is charged by Kilowatts per hour - There is a very easy formula for you to determine how much electricity your unit consumes.
Locate a sticker on your unit, it will usually say something like 120VAC follow by a number with A....... example 120VAC (which means 120Volts alternative current) and 5A (5 amps). Locate those 2 numbers, multiply them together.
Here is the formula: V*A=W (Volts * Amps = Watts)
So example if you have 120V 4A, that makes 480 W !
Sometimes on some units it already says the wattage, expressed in W Example 100 W !
Once you determined the WATTAGE, divide it by 1000, that gives you your KILOWATTS.
So example, unit uses 400 W..... you will do 400 / 1000 = 0.4 KiloWatts / hour
Next, locate your utility bill and see how much they charge per Kw/h. Multiply your unit's Kw/h * hours per day operation * rate = the cost per hour !
Example
0.4 kh/w * 10 hours * 0.07 (7 cents) = 28 cents per day!
Sep 26, 2009 | Hamilton Beach Water Cooler with Storage...
Daily cost to operate
electric is billed at so many cents per kilowatt hour. a kilowatt hour is 1000 watts per hour. if your heater is rated at 3000 watts, running it for one hour will consume 3 kilowatts of energy at whatever your utility charges per kilowatt. if the amount on your bill is .026 per Kw it'll be 2.6 cents per hour.
Nov 19, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
Samsung Hue (SCH-r500) Cellular Phone Logo
229 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
