Question about RCA D61W20 61" Rear Projection Television
White smoke coming from the back
It's a 32 inche, RCA tv. Plays good, still have picture and volume. Its just that after being on for awhile, it start smoking from the back ( white
looking smoke).
What can be causing this?
Posted by mgolette825, on 12/10/2008
  • 60 Answers
I advice you don use this anymore and contact one authorized service to fix that problem there is an supply problem and could go worst
That smoke could be from one component like one rezistor or electrolitic capacitor but you cant fix that yourself
Posted on Dec 10, 2008
When I play a dvd on my toshiba 32 inch tv, it plays in blank and white.
Go into your MENU and choose Picture. Once into the picture sub-menu you wiil have options to set the color, tint, etc. to your personal liking. Best Wishes
Sep 01, 2014 | LG 32LG30 32 in. LCD HDTV
Color on TV changes to black and white, then after awhile changes back
It is possible to be the box, and not your tv. A good way to test is to see if it does it when you are watching a dvd or another source. (game system, blue ray, ect) Hope this helps! Good luck!
Dec 04, 2013 | Televison & Video
Have 32 inch rca, says no signal, blue screen, plays dvds great has good picture, how do i get tv picture on?
IF plays DVD's via the audio and video jacks on the set there is a option here--bypass the issue with a box (cable or sat or any kind that will pass the signal via the same connections you use for a DVD.
The blue screen suggests you have or may have a bad tuner in the set--cannot beat it get around it.
Jun 11, 2012 | Televison & Video
32 inch toshiba tv plays awhile then goes off and wont come back
It is very possible that you have solder joints on the main board that need to be re-soldered.
Dec 29, 2009 | Toshiba 32A33 32" TV
Model f 27442 27 inch rca have volume but no pic it is all black screen
Find coil L14401. It is next to your Horizontal output transistor. and next to a 100 ohm resistor. This coil may have have a red glue on the ends. Unsolder this coil and carefully scrape the ends, and scrape the or clean the board where the coil was. Now reinsert this coil and resolder. You will have your TV picture back! Good Luck and thanks for asking!
Oct 21, 2009 | RCA F32650 32" TV
GE television
My GE 32 inch won't come on, when you turn it on you can hear click two to three times then it comes off.
I have another 32 inch GE TV that has no picture except white/gray light on the picture tube, but there is sound
Oct 20, 2008 | GE (-25001RE2) Audio Conference
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
RCA TV
Look for bad solder connections on the solder side of the board: You have to take board out of the plastic and slides out. Look around the high voltage transformer pin connections and large transistor associated with it and all connections associated with it too. Use magnifying glass. Could be hard to see. You could also shotgun the whole section by just soldering all associated connections. Look for burned connections also.
Dec 27, 2007 | RCA F32650 32" TV
RCA D61W20 61" Rear Projection Television Logo
98 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
