Question about RCA HD61LPW42 61" Rear Projection HDTV
What to do?
About 6 months ago, the projector light failed. After replacement, I noticed a faint buzzing sound coming from the TV. It has gotten progressively worse and, to top it off, the start-up time has gone from a few seconds to more than a minute. However, the TV now is cycling on and off about every 45 seconds, or so. Sound still works, but the set powers down, then suddenly comes alive. As if you turned the set off, then manually turned it back on. I hate to call a technician, but it's looking like this might be my only solution. HELP, please.
This unit also has ballast problems.You most likely will need to call a tech for replacment.
Posted on Mar 04, 2007
Should an LED t con board make a light buzzing noise?
Hi Anonymous,
It looks to be a case of failed backlights.
Jan 23, 2016 | LG 55 55LW5600 3D LCD TV
Sanyo DP42740. Backlight comes on to a dark grey screen, No menu or sound, Power button does not work, SN board does have a green light on it, No visible bad caps, I am suspecting the T-Con board????
Eric has been too busy to work on this TV, so I got it from him and am continuing with it. As soon as power is connected to it, the screen glows slightly, but you can only notice it when all other lights are off and the room is dark. But the TV does nothing else. I initially though it was the power supply board and replaced it, same result. I then noticed that there was a faint buzzing or humming sound coming from the X-Sustain board.
Thinking this was finally the problem, I replaced it too. Blast! No go. Ok, so now that we've narrowed it down, it HAS to be the Y-Sustain board Right? I don't think we can afford another board. What is it that fails on these boards? Could I just replace one or two MOSFETs? How do we determine which ones are bad? Thanks for your help.
Sep 25, 2013 | Sanyo DP42740KNB 42 Class Plasma HDTV -...
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
Light engine problem?
sounds like your ballast is bad let me know your model number and I should be able to help you
Apr 11, 2008 | Mitsubishi WD-52627 52" Television
My Pioneer SD-P5071-K has a very faint picture
THERE ARE 9 ADJUSTMENT POTS ON THE FRONT LEFT SIDE OF THE UNIT BEHIND THE SPEAKER COVER WHICH POPS OFF IF YOU GRAB THE OUTSIDE EDGES. ADJUST THEM THAT WILL FIX IT.
Dec 13, 2006 | Mitsubishi VS-60609 60" Rear Projection...
RCA HD61LPW42 61" Rear Projection HDTV Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
