Question about JVC Car Audio & Video
While testing before final installation of the JVC KD-G240 CD Player, the only power I can get is to eject a disc and temporarily display the time. I cannot turn the unit on. After pressing the reset button, the problem still exists. Help!
  • nwsa Dec 13, 2008
    Thank you very much. Your absolutely right. Problem solved!
    President:
  • 624 Answers
This is an indication that the "ACC" line is not getting the 12 volts to turn on the radio. Check the fuses, it may have blown one. The "ACC" is the red wire that comes off the back of the radio harness. It needs a 12 volt supply when the key is turned on for the radio to work properly. When this is missing, you will have the conditions you have described. The yellow wire is for a constant 12 volts even when the radio is off and the car is off. Since you do get the eject and the clock display you have a good ground, so that is not an issue. You just need to find out why you do not have the 12 volts on the red wire when the key is turned on in the car.
Posted on Dec 10, 2008
  • Dave DeGain
    Dave DeGain Dec 13, 2008
    Since I was "absolutly right", wouldn't that rate a "FixYa!" instead of a "Helpful". After all, that is the apropriate rating when you solve someones problem.
    In any case, I am very glad that I was able to help you figure this out. Have yourself a great holiday this year.
    Dave
No se como activar el bluetooth
pon el modelo del radio para poder ayudarte!!!
Jun 02, 2010 | JVC KD-G230 CD Player
Jvc kd-r200 wont power on
you have the red and yellow wire on the radio mixed up switch them
Apr 25, 2010 | JVC KD-G110 CD Player
JVC KD-G140 Chevy s10 problem
Your headunit is getting constant power (yellow wire). You most likely have no switched power (acc red wire). You can be certain by testing the red wire w/ a 12 volt test light when your ignition is on. If there is no power to this wire then you probably have a blown fuse. The radio fuse should be a 10amp fuse located in the drivers kick panel.
May 28, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
My JVC KD-G331 Cd Player Won't Work In My Clio (X reg)
Hi, did you fix this problem?
I'm having exactly the same issue myself.
Jul 03, 2008 | JVC KD-S6060 CD Player
Unable to play MP3 CDs on JVC KD-G140
I had this same problem and realized after reading the manual that this model does not play mp3's. They use the same manual for the g140 and the g240 (the model which plays mp3s).
May 19, 2008 | JVC 50W x 4 MOSFET CD Deck with MP3...
JVC KD-G200 cd player
I would suggest checking the accessory (red wire), the yellow is a constant feed from the battery, which will allow the clock to be displayed no matter what. The accessory wire is what is used to turn on the cd player. You may need to restrip the red wire and check the lead going to the red wire with a test light to make sure it is getting a voltage light.
Mar 03, 2008 | JVC KD-G200 CD Player
Power will not stay on
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Aug 11, 2007 | JVC KD-PDR30 CD Player
JVC KD-SX770
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
May 18, 2007 | JVC KD-SX770 CD Player
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Nov 11, 2006 | JVC KD-S580 CD Player
Car Audio & Video Logo
85 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
