Question about GE GSH25JFR Side by Side Refrigerator
GE Ice dispencer not working properly
Ice dispencer on my GE GSH25JFRFWW side by side refrigerator / freezer works Intermittently and when it does not work the LED dims and the light in the dispenser dims also and if you keep trying to use it the refrigerator will stop working and you have to unplug it for a period of time to get it to start cooling.
  • 3 more comments
  • JoeWyo Nov 02, 2007
    Ice dispencer on my Hotpoint HSS25GFPJWW side by side refrigerator / freezer works Intermittently and when it does not work the light in the dispenser dims also and if you keep trying to use it the refrigerator will stop working and you have to unplug it for a period of time to get it to start cooling.
  • Kim Cook Nov 13, 2007
    My ice maker is working properly but the dispenser isn't. The in door water and ice dispenser won't work. When a glass trips the paddle the dispenser light dims and there's a electrical groan, like it's trying to work but the auger is blocked, but it isn't.
  • FTIR king Nov 19, 2007
    My Ice maker is working but the crushed and cubed ice won't dispense ice. When the paddle is pushed in to get the ice, the light dims and the small ice door doesn't always open but no ice is dispensed. The auger doesn't turn and the solenoid doesn't energize for the crushed ice. I replaced the 5 button fornt panel but no help.
  • tonypanda Nov 27, 2007
    The other post says it all just started today oh and my fridge moans also this is covereed in another post seems to be the same fix, change the main electrical board
  • Anonymous Dec 16, 2007
    The motor that drives the cube auger doesn't run. I took it out and it had a small coating of frost on it. I clipped a 115 vac jumper onto the motor terminals and it would not run. After the frost melted, the motor would run OK. Is there a small heater element somewhere that keeps frost from building up on this motor?
    John
    Scholar:
  • 35 Answers
For a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Posted on Mar 27, 2008
I have a similar model refrigerator and problem and had a techincian look at it yesterday. He replaced the main electrical board on the back of the refrigerator and told me it was covered be a factory recall or extended waranty from GE didn't charge anything, said that GE was covering the cost.
Posted on Jun 19, 2007
  • 72 Answers
Sounds like the motor that turns the ice auger is overloading the system, maybe shorting to ground.
Posted on Mar 03, 2007
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge freezer profile
the fridge needs servicing....if you still have waranty use it.
Nov 12, 2007 | GE Profile PSI23NCR Side by Side...
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
How do I fix freezer so it doesn't have so much
check that the dispenser door is shutting properly and seal is OK also check if ice is not jamming door open also check that freezer is not to cold
Nov 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Makes ice sparatically and will not dispence ice
Make sure freezer running at proper low temperature. Absolutly requires proper temp to operate properly.
Jul 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GSS22jerfww ice dispencer?
Main Ctrl board bad WR55X10552 is the part you need the board has a short it is on the back wall of the unit I will bet when you press it in the compresser turns off as well !!!
May 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Panel out
Replace the control bord if there is no function.
Jul 10, 2007 | GE Profile PSW26P Stainless Steel Side by...
Water Dispencer not working.
check your freezer for ice. do you have alot of ice in your ice maker tray? if so your water line could be frozen. try to self defrost the freezer for about 3hrs to thaw out the water line. check your water valve also. when you call for water do you hear a humming or buzzing noise? on ge fridges ive worked on if you hear a humming noise when calling for water, most likely your water valve is ok. trace the water. meaning where does the water start? at the wall then through a hose then to your valve which is behind fridge on bottom. trace the hoses and you will find the prob
Feb 09, 2007 | GE GSS20IEP Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
821 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
