FixYa.com
Tags:
Zenith Data Systems Zenith  Plug-In Module 24x CD-ROM Drive
My CD-R drive loses connection to computer while...
By Reynolds - usenet poster
my CD-R drive loses connection to computer while writing, help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 13, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
sqddddddddd
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 07, 2007
Not Rated (0)
HITESH
Rank:Master Master
Rating: 78%, 19 votes
1. Pls check the proper power supply
2. Pls also check that you are writing how much data. It looses connection at some 10-12 mb data or higher.
3. Some times the saft of motor drivring the read write head get loosed due to heavy writing and readinding and the cd drives shows the bklinking light outside but nothing can be read or write.
4. Ensure that rhe motor saft is ok.
Solution #3
posted on Aug 08, 2005
Thanks for Trying (70)
Janice
Janice - usenet poster
Rating: 0%, 0 votes
1. Try writing at slower speed and with all other applications closed.
2. Upgrading your operating system can confuse your CD-R drive. Check drive manufacturer's Web site for compatibility info on your system.
3. Download and install up-to-date drivers for CD-R drive.
4. If cables are defective or too long, try different, shorter cables.
5. For universal serial bus (USB) drive, try plugging it directly into USB port on computer rather than into hub.
6. For FireWire drive, connect drive to computer only after both drive and computer have been turned on.
7. Set CD-authoring software to Disc-at-Once if that option is available.
8. Make sure CD-R drive is isolated from loud noises and vibrations while writing.
9. Try different brand of blank CD media.
This Problem Also Relates To: HP (288894-001) Internal 48x CD-ROM Drive HP (372703-B21) (372703B21) Internal 24x CD-ROM Drive HP (212489-6B0) (2124896B0) CD-ROM Drive HP (176135-630) (176135630) Internal 48x CD-ROM Drive Memorex 32023252 Internal 52x CD-ROM Drive Sony (PCGA-CD51/A) External 16x CD-ROM Drive Apple (661-1401) Internal 24x CD-ROM Drive
Can you Help with these CD ROM Drives problems?
CD ROM Drives
GenCdRom
my cdrom cant be install code... Answer This...
CD ROM Drives
theory test complete
just bought the theory test... Answer This...
CD ROM Drives
problem with operating system
i have got compaq notebook.but... Answer This...
CD ROM Drives
emiliano cabral rep.dom
i have problems to install my... Answer This...
CD ROM Drives
Finding my saves on DVD Rom
Press save on Syberia... Answer This...
Repair Service
Find CD ROM Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
