Question about HP OfficeJet 6110 All-In-One InkJet Printer
My computer is not reading my printer's disk, it states that the disk if not formatted or files may be corrupted. How may I obtain a replacement disk: "version 2.00 hp psc2100 & 2200 series, hp officejet 6100 series, windows 98,2000, ME,XP" I'm currently using Microsoft XP Professional version 2002 operating system.
  • 2,110 Answers
Catastrophe. A corrupted mp3 caused my Ipod to dump all files and now Itunes cannot read it to do a restore. Is there anything else I can do?.
Are you sure this was a corrupt MP3 that went on to the iPod, rather than an MP3 that the iPod itself corrupted?
Maybe as a result of a dying hard disk?
Dec 10, 2013 | Apple 160 GB iPod Classic (Silver) +...
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Jun 03, 2008 | Sony Playstation 3 (PS3) Console
PNY Optima SD HC Card cannot be read in HP Photosmart 8150 printer.
  1. Verify that the printer is turned off.
  2. Remove the Secure Digital memory card from the printer.
  3. Examine the Secure Digital memory card:
    • Is the lock switch in the unlock position?
    • Are there any visible discolorations or defects such as crack or nick in the card?
    • Are there any contacts missing from the end of the card?
    • Are there any deep scratches in the card contacts?
    • Is there any heat discoloration on the card? NOTE: If all of the above questions result in No , proceed to Step 4.
  4. Check if the HP Photosmart printer supports the file format. NOTE: In order to know which file formats are supported by the different HP Photosmart printers, please refer to the manual of your printer.
  5. (Saving the pictures on the PC, if possible) Insert the Secure Digital memory card in the camera (or another device) and format it following the proper instructions to perform it.
  6. Capture an image.
  7. Review the image. If the image is corrupted or an error such as Unsupported Image File is displayed, the Secure Digital memory card is suspected to be defective and should either be replaced or referred to the manufacturer for further troubleshooting.
  8. If the images are read properly, turn on the printer. Insert the Secure Digital memory card in the Secure Digital slot.
  9. If the printer display continues to show the Card Not Recognized error, try using another Secure Digital memory card, if one is available.
  10. If the printer is still unable to read a functional and compatible Secure Digital card, contact HP to obtain additional troubleshooting information.
Oct 05, 2010 | PNY 4GB Secure Digital High Capacity...
I have 3 1/2" floppy drive SmartDisk FDUSB-B2. If I load a 3 1/2" floppy which contains data, the drive will read the data wihout error. When that same disk is removed from the drive and re-loaded the...
Hi David,
Likely the drive is out of alignment, and head position changes each time that you insert a disk. You might try reading the disk on a different machine and try to get the data off. But, if the drive is too far out of alignment, even this won't work.
This is also a sign of 1) Drive motor turning too fast / slowly (likely), or a viral infection of your computer.
I also have the same drive that you do, and began getting a few read / write errors when making bootable disks. Problem ultimately ended up being worn out media. Resolution was to start using USB memory sticks, but harder to boot on machines that don't have BIOS support for this.
Aug 12, 2010 | Computers & Internet
TSSTcorp CDRW/DVD TSL 462C not reading some disks
The optical unit reads the disk, no problem with it apparently. This is easy to test - just put the disk in and open My Comp, in there just open the disk and if it's read the actual files will appear.
Your problem is caused by the fact that the files on your disks are in a format your Media Player is incapable of playing. So just get a better one, the best being VLC.
Jul 22, 2010 | Toshiba Computers & Internet
Ps3 hard disk file is corrupted
This problem always happen when you switch off your console while it is saving data or reading data from the HDD, so your HDD file system damaged, in order to solve this problem you need an external SATA 2.5 hard disk case, extract your PS3 hard drive and insert it in the SATA 2.5 case, plug your hard dist to a computer, you will find that the whale hard disk is unallocated, so format it with FAT32 or NTFS using your computer, after that return your hard disk to your PS3 console, now, your PS3 console will recognize it, and it will ask you to format it, say YES!!... congratulation your PS3 console is working now
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
Hi everyone, I would just like to know, does anyone know how I can obtain or create an emergency boot up disk for windows xp home edition? Many thanks. Andrew
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
Jan 15, 2010 | Computers & Internet
.pst file not extracting, stating there is not
Some possibilites:-
1/ The zip file containing the .pst is corrupted.
2/ The target disk is not being correctly specified.
3/ The .pst file is very very large.
Nov 05, 2009 | WinZip 9.X for PC
H:\ not accessible The file or directory is corrupted and unreadable
how can i solve I:\ is not accessible the file or directory is corrupted and unreadable
May 23, 2008 | Computers & Internet
HP OfficeJet 6110 All-In-One InkJet Printer Logo
59 people viewed this question
Ben Johnson
