Question about SanDisk Sansa Clip MP3 Player
Did a recording plugged in ear plugs and now it is frozen
I made a recording and plugged in the earplugs to listen to see if it picked up. Now I have removed the ear pieces and it is frozen??
  • 8,596 Answers
Reset the player first.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
When I put earplugs into the computer to listen to something they do not work. I can not hear through the earplugs. I still hear through the speakers of the computer.
If you have the ear plugs connected to correct output they should work unless the earplugs are no good. Try with another computer to see if they work and draw your conclusions.
Nov 18, 2015 | ASUS R X551MA-RCLN03 Laptop Computer With...
DOES THE APPLE ALLOW YOU TO PLAY MUSIC WITHOUT THE EARPLUGS?
The iPod does not have built-in speakers. You can plug external speakers into the earplug jack.
Jul 27, 2012 | Apple iPod MA446LL/A MP3 Player
Sometimes when my headphones are plugged in to my iPod the music only comes out of one earplug. How do I fix this?
Check wheather headphone is attached properly or not then, take it to the mechaniche ,verify that the solding is not dittached..........
May 01, 2010 | Bose in-ear headphones - Black with...
Right earplug is shorted out. sound goes in and out. how do i fix it?
The right ear plug internal wire is cut off due to wear and tear. This is common problem with earplug especially if
if you pull by the wire of your earplugs. The solution is to
cut open the wirings of your right earplug and reconnect,
resolder it, and tape the bare wires, to restore the sound. However, it will be unsighty. So, the best thing
to do is to buy another.
Oct 13, 2009 | Etymotic Research Isolator ER-6i Consumer...
I cant hear from my earplugs ....
Helllo,
There is probably a problem from your ear plugs if it works on the system. Probably the cord is cut or the connection in the earplugs is bad. would recommend getting a new one.
cheers
Sep 18, 2009 | Computers & Internet
Headphones are only working in one ear.
This is a common problem. All stereo adapters will only play in the right ear. What you should do is send back the headset adapter and get a stereo headset that plugs directly into the 2.5mm jack, without going through an adapter. That should solve the problem.
Aug 03, 2009 | LG VOYAGER VX10000 Cellular Phone
Vn-3100 non pc
I beleive that recorder is mono. You have to use an adapter for stereo headsets or listen on one side of the head set.
Accessories are available at olympus.com
Jun 30, 2008 | Olympus VN-3100PC Digital Voice Recorder
Acer 3680 sound on headphone
I wish I knew what you was asking when you plug the ear fone into the right jack everything goes good but theres no sound in the earplugs yet wen you eject it puts a ballon on the screen sayin no jack is in the plug can you explain what you want......... its bugging me Im not sure what you want and Ive rad your problem four times.
Aug 30, 2007 | Acer Aspire 3000 Notebook
SanDisk Sansa Clip MP3 Player Logo
37 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
