Question about Abit NF8-V Pro Motherboard
Abit nf8-v keeps beeping when turned on. no video
Amd-athlon 64 3000+ socket 754
been working for a while and then i reformat and reinstall everything, cd drives would not work anymore after installing the motherboard drivers.
turned on computer and getting no video. i get continuous intermittent beeps. "beeeep.......beeeep......beeeep...." It continues to beep even after I unplug everything except the chipset. I reset cmos, nothing. changed out ram, no difference.
  • 2 more comments
  • epyzero Dec 11, 2008
    they are all long beeps. they continue till i shutdown. the beeps last about 2 seconds each
    sorry, umm memory board? the ram? I took the whole computer apart and put it together again. I tried putting in a new video card to see if the video card was the problem. no video still and still has beeps.
    everything is seated properly.
  • epyzero Dec 12, 2008
    my warranty just ended a few months ago...
  • jshtate May 11, 2010
    have you made certain the memory is seated in the primary slot?
    Scholar:
  • 111 Answers
How is the beep sounds? Long beep and three short beep or one (-...) or all long beep?
For the first, usualy the VGA connector is not correctly seated, so the motherboard can say it has no output device and beeping.
The last is usually memory problem. Try, unplug your memory board and replug it again, make sure that it is correctly seated.
Posted on Dec 10, 2008
  • Dapid Candra
    Dapid Candra Dec 11, 2008
    I'll check your board documentation, there might be some useful information.
    BTW, last time I got similar problem, I return the board to the distributor and got replacement. Might worth to try, if your warranty still available.
2 Suggested Answers
shibuda
  • 1812 Answers
SOURCE: I've AMD Athlon 64 bit
you must plug in your pc with ups
do step by step from internet and alwayas choice last date
http://support.asus.com/technicaldocuments/technicaldocuments_content.aspx?no=714
for download =http://drivers.softpedia.com/progDownload/Asus-K8S-MX-Bios-1013-Download-13287.html
1st thing you'll need to do is go to the motherboard manufacturer's website & download the new BIOS file & the flashing program. These 2 files will have to be copied to a bootable floppy, then you'll have to boot off it & do the update from DOS. The motherboard website should have a detailed explanation on how to perform a flash...print out the instructions & follow them exactly & you should have no problem
Posted on Nov 12, 2010
What does code 7f mean on kv8 pro
Did you ever resolve?
This is the board with the external OC monitoring panel, right?! I owned this, too. I had a similar KV8 board from Soltek, as well--post codes, also. My Abit died several years ago.
The ABit's manual still exists online. According to the code, It's hanging on the onscreen logo--it says to switch to text. Here's the page describing your code: http://www.manualslib.com/manual/615/Abit-Amd-Athlon-Kv8-Pro.html?page=69#manual
If I remember correctly, that's not a serious error code--popped up often after new installs.
If it's a hard drive error--do you have the master/slave configuration jumpers correct? (Hard drive vs. Optical drive? Probably, you want the hard drive as master--optical as slave)
Is cable orientation (Pin 1--from PATA cable and at drive(s)/board) correct? Perhaps I remember now--maybe the BIOS can't get to the hard drive and OS.
Is your floppy light always illuminated (it shouldn't be)--is that cable installed correctly?
If your onboard hdd controller is dead--and, you worked with AGP over the years--you likely have a PCI card that will take its place. (If not, you may purchase that pretty easily. still.) Syba, Siig, Sabrent, StarTech, etc.
If your controller is OK, have you tried running a live i386 (32-bit) or AMD 64(64-bit) Linux disk or an old Bios upgrade/DOS floppy--to see if you get some type of OS posts? Is your proc 64-bit or 32-bit?: If I remember correctly, 754 CPUs generally were 64-bit--some were 32-bit, though (I still own one of those, too).
Did you clear your CMOS first (move the jumper for a few seconds and back)? Is the jumper correctly installed now?
Ah, the days of socket 754 (I never obtained Socket 939.....) Socket 754 still is a good value--you may obtain such a proc for about $5 on Ebay. (Used boards are a little pricey--considering.) I get the sense that 754 was the business board--939 was the gamer board.
Recently, I resurrected my old Shuttle Athlon XP board--considering its age, it holds up pretty well. Works fine with 32-bit Linux Debian distros. Dual-channel. Great OC board in its day. Currently, I have a 9800XL card in--soon, I'll put in a 3850 AGP....
May 23, 2014 | Abit KV8 Pro Motherboard
I am using ASUS K8VMX motherboard with AMD Athlon 64 2800+ motherboard. Now my motherboard has gone bad. I want to change it. Suggest which motherboard should i use (754 socket)
Whatever board that is in a microATX format and has a 754 socket will do - they all had the same general hardware characteristics and requirements - so get the cheapest you can find.
Apr 17, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
I have an Abit NF8 series motherboard and am using a amd 3200 --- I am wondering if I can but in a bigger processor as I am running 2.2 ghz and I need 2.6 for a game I would like to play. Is it...
You can put in bigger processor, Any AMD Athlon or Sempron will do.
If you are planning to run big games, then I suggest you get
- A new motherboard with PCI Express 2.0 support
- A new processor
- A new graphics card (maybe 512 MB or 1 GB) with DirectX 11 hardware support and Shader Model 5
You may make that DirectX 10 or 10.1 and Shader 4 if you want to reduce cost.
Aug 13, 2010 | Abit NF8-V Motherboard
I am using amd sempron LE-1100 i want to upgrade to a gaming pc so that i can play the sims3. so if i like to upgrade to amd athlon x2 how to know my socket type. please help
Your socket is AM2. You can put any AMD processor that has AM2. If the processor is AM3 just upgrade the bios of your motherboard and it should work. If you need further assistance, just leave a comment. Cheers
May 24, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
How do i reformat amd semphron?
Sempron is the AMDprocessor targeted to the entry-level market and can be found in two platform versions: socket 462 (a.k.a. socket A), the same motherboard type used by Duron and Athlon XP, and socket 754, the same motherboard type used by some Athlon 64 processors.
If you are talking about reformatting the hard drive an a machine with this processor, make sure you have to original  install disk including the windows disk or the reinstall disk for that name brand computer. Igf you have everythingh you may go to the HD prompt,usually "C" and click on formatt.  DO not do this unless you have al the software you need as it wil clean the whole hard drive. After reformatting reinstall everything. The Sempron CPU will not be harmed.
Dec 13, 2008 | Computers & Internet
IS MCP61S THE SAME AS NF61S MICRO 754
Biostar offers NF61S MICRO 754 Motherboard + AMD Mobile Athlon 3200+ (COMBO56), NF61S MICRO 754 Motherboard + AMD Mobile Sempron 3300+ (COMBO56A),NF61S MICRO
Motherboard Processor:
Socket 754
Supports AMD Athlon 64/Sempron Processor
Support AMD HyperTransport up to 1.6G
Supports AMD Cool'nQuiet Technology
• Chipset:
NVIDIA MCP61S(GeForce 6100/nForce 405)
they are the same motherboard .hope this helps pls appreciate by rating it as fixyaa
Oct 10, 2008 | Computers & Internet
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Abit NF8-V Pro Motherboard Logo
458 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
