Question about Smith Corona Wordsmith 100 Typewriter
Daisy wheel will not stay on wordsmith 100
We can align & get on but it will not stay on. There is a little clip on side, looks like it is suppose to lock it on, but it doesn't hold. everytime you type it pops off.
  • cgarner Dec 13, 2008
    thank you, As it turns out, the typewriter is worn out and will not hold the wheel in. I did try your suggestion, and I thought it was going to work, but it won't hold
  • 549 Answers
CHANGING Changing The Ribbon Cassette 1) Move the print carrier to the center of the platen using the SPACE or BS key. 2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette. 3) To insert a new cassette, place the back end of the cassette on the cassette holder on the carrier and gently press down on the front of the cassette unit it clicks into place. 4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon. 5) Presss the CODE + = (SETTING) key.
Changing The Print Wheel 1) Move the print carrier to the center of the platen using the SPACE or BS key. 2) You will see a lever on the right side of the carrier. Pull this lever toward you and lift out the daisy wheel. 3) Place the daisy wheel into the slot with the characters facing the platen. 4) Push the lever back into position. 5) Press the CODE + = (SETTING) key.
It appears as though you have something that is preventing the print wheel from being locked in place by the release lever. It should make a snapping or similar noise when it is locked down.
Posted on Dec 10, 2008
Cub cadet 3 stage snow blower auger will not stay engaged when left handle is released as it is supposed to while holding down the right handle.
There is a little clip/notch/piece of plastic inside the dash right by the left handle. It's bent or broke.
Mar 16, 2017 | Cub Cadet Garden
Soap dispenser pops out a little bit when machine is turned on
Hi Kare
Look to see if plastic catch is broken, missing or out of alignment.
If plastic clip is not holding because of ware or bent the wrong way.
You can remove drawer, clean it and gently heat it with a hair dryer and carefully curve back to the correct side!
Careful.... Warm Bends Cold Snaps!
Mar 05, 2015 | Washing Machines
Door lock actuator
This solution is for a 1998 Ford Taurus door lock actuator replacement. In this solution, I'm working on the front passenger door of a 1998 Ford Taurus SE (4 door). I installed a new door lock actuator from Advance Auto Parts, it's a Dorman 746-145, about $50 list, my cost was about $30 with a coupon I got by googling Advance Auto Parts Coupons, and applying a code at checkout.
Disconnect the negative battery cable.
Remove the interior door panel: Unscrew and remove the push/pull thing used to lock and unlock the door manually. Remove the 2 Phillips screws on the sides of the interior door panel. Remove the Phillips screw that's in the bottom of the interior door handle. Use a large screwdriver to pry the lower right hand corner of the interior door panel out, you may or may not be able to pop the clips free, work your way across the bottom and up the sides, pulling or prying or both. Pop it free all the way around, the top center clip can be a bear to get free. Make sure all the other sides are free, then get the top center clip. I think I pulled the top right of the panel to the top right, over the top of the door lock rod/button, and then it just popped free.
Remove the wiring harnesses for the electric window and electric lock buttons inside the panel you just removed: Push the button in, and pull the ring extending around the button for something to grip to pull it free. Rocking it a little seems to help. I used channel locks once a few months ago, but be careful.
The panel's free, set it aside where it won't get broken. You can leave the speaker in.
Pull the plastic water barrier off of the right half of the interior of the door. Take some tape or something and tie it down on the left side of the interior of the door, you'll be working on the right side only.
Take a look into the bottom right corner inside the door with a small flashlight. There's the actuator. Take note of the new part, and the old part, and the way the rod's connected to the actuator.
Note the Position of the actuator in the door, look at the new actuator, the wiring release clip is on the right (towards the steering wheel if the door were closed).
You will NOT need to remove the rivet that's in the actuator bracket. It just holds 2 pieces of the bracket together.
Remove the two 11mm bolts at bottom right that hold the actuator bracket and window track/rail in place.
Remove the 3 torx screws on the edge or end of the door, that hold the door lock in place. Don't worry, everything won't fall apart, you'll be fine.... :)
Now you'll need to find out how much slack is in the wiring to the bottom of the actuator. Do not pull on the wires. But you do have to take off the wiring clip from the bottom of the actuator. If the wires are long enough, push the window track/rail out of the way and swivel the bottom of the actuator towards you a little for easier access. I used a small flat blade screw driver to hold the locking clip out, as I pulled the wiring clip off the bottom of the actuator. Good Luck......
You won't be able to see much, so take a good look at the new actuator before trying to take the wiring clip off the old actuator.
Now to get the Actuator out of the door: Carefully push/move the window rail/track out of the way, moving it as little as possible, don't kink it, while pulling the actuator towards you. The actuator connecting rod will swivel where it connects above (at the lock), and allow you to move it.
Once the Actuator is clear of the window rail/track, take a screw driver and push the lock itself in as far as is necessary about an inch or so), while holding the actuator with the other hand, continue holding the lock in with the screw driver, while maneuvering the actuator to free the connecting rod from the lock assembly above. A half twist/turn is about all it takes to free it. Note how to reassemble it before disassembling it.
The actuator with the connecting rod on it is out of the car door.
Now for the hard part, use pliers or screwdrivers or whatever it takes, and remove the old clip that holds that connecting rod to the old actuator.
Hold that connecting rod up to the new one.
The new one I got was a little bit longer than the old one, and would not work until after I ground about 1/16th of an inch off the end of it. Making it identical to the old part. I recommend using the old connecting rod. Easier.
You'll still have to use the new clip on the connecting rod either way. With O-rings. I used a new o-ring on the top side, and an old o-ring on the bottom, because the old o-ring stayed in place by itself, and the new one was larger, and fell off the connecting rod. Bend the old o-ring and make sure it's not full of cracks before re-using it. Ace Hardware probably isn't too far away....
Before attaching the locking clip to the connecting rod, put the rod into the new actuator. There should only be enough extra room for the o-ring. If there's more room than that, you won't be able to get the locking clip on. Meaning, you'll have to use the old connecting rod, or grind some off the new rod. Put the old connecting rod in the actuator, and the new connecting rod in the actuator, if the space is the same or less for the new connecting rod, you're ok. If it's just a little bit more, it probably will not work.
Once you're certain your connecting rod is the proper length, assemble the connecting rod of your choice to the new actuator using 2 O-rings and the new connecting clip that came with your new actuator. This will not be easy. I had to get Fay to help me. she complained her fingers were getting pinched, so I had her hammer it on, and yes, my fingers got pinched. But no blood. Just pinched. Maybe I should have held it with pliers instead of my fingers....
I used I think it was a 3/8" line wrench (probably the smaller the better, this was the smallest I had), over the top the the new clip, and hammered it onto the new actuator. By hammered, I mean barely tapped on the wrench with a hammer, while the line wrench was perfectly positioned on the clip - to drive it onto the actuator. Stop when it's on, or you may break something.
After it's on, turn the clip a little (say half a turn), if it stays on, leave it.
The rest is pretty obvious. Pry the bracket off the old actuator (I used a flat blade screwdriver), noting it's position on the old actuator, and put it on the new one.
Push the lock in with a screwdriver (thru side of door), just enough to attach the rod on the actuator back into its place on the lock assembly.
Putting it back together is easy. Just don't forget any of the bolts that were removed. Start the 3 bolts that hold the lock. Start the two 11mm bolts that hold the actuator bracket and window rail/track. Tighten those 5 bolts. Hit what you can with a spray can of white lithium grease (Walmart has it next to the carb cleaner). Hit the lock, linkage, I even hit the window track. But not the wires. Work the manual lock button up and down making sure everything works freely.
I siliconed the water cover back onto the door (silicone was handy), then reattached the door panel. Connect the window and lock wiring first, and don't forget the 3 screws that hold the door panel on. And attach the door lock button that screws onto the top of the that door lock rod last.....
Reconnect the negative battery cable.
Test the lock actuator.
Mine was binding at the top, where the manual lock button goes thru the hole in the door panel. I probably should have bought new skinnier lock buttons, but I had the grinder out anyway, so yes, that plastic/rubber button got ground down. All the way around. Works fine now. This was probably the cause of that actuator going out.
Good Luck to You with Yours.... :)
Aug 22, 2013 | 2006 Acura TL
Bread pan comes loose and bangs around during kneading cycle--how to fix?
Hello....I wrote this for those with bread pan problems....be sure to read the part about how to restore the "spring" of your bread pan clips...
Bread pan removal:
I am assuming you have the type of bread machine that has the little metal spring clips inside the oven compartment. Before inserting the pan always check on the bottom of the pan (underneath) to see how the impeller "T" is aligned and turn it with your fingers or turne the paddle with your fingers so the "T" will fit into the gaps of the impeller in the bottom of the oven. Once you have aligned them then place the pan in the oven and "pop" push the pan in place so the spring clips grab the matching clips on the sides of the pan. Also look to see if your pan has the word "front" stenciled in the lip edge of the pan. If so, be sure that edge is towards the front of the machine. If your pan still won't pop into place when you push down your spring clips may need to be gently pulled out because they can become "slack" over time. Take the pan out and reach in and pull each spring clip up until you start to feel it bend a little and bend them out. Pop your pan into place and if the clips don's start to grab your pan repeat the process of bending the clips out and repeat that until they do. Summary:
1) make sure if your pan is marked "front" that it is aligned properly
2) make sure the paddle and the T underneath the pan aren't in conflict with the matching drive impeller in the bottom of the oven. Just turn the paddle so they are opposite of each other and can engage
3) Restore the "springiness" to your clips by bending them out with your fingers. Be careful though because the spring edges are fine edges so get underneath them when you pull up
For bread machine parts, good used bread machines etc. visit breadmachineshelp.com
Apr 01, 2013 | Breadman Tr2500bc Ultimate Plus 2-pound...
I have an imate pda2k pocket pc and is working good. Out of curiosity i tried hard reset and it ends to align screen. Everytime i made a hard reset the screen show " tap the screen to setup your pocket pc"...
tap and hold on align target until it moves to next corner or next step, if you are using windows 6 or 6.5 you should be very much accurate on taping and holding to align the screen.
Nov 01, 2009 | i-mate PDA2k Pocket PC
Driver side car seat side panel will not stay latched
you need new clips ,avable through subaru,i believe they are better than ones equipped originally
Apr 06, 2009 | 2005 Subaru Outback
2000 mercury mountaineer door rod off of key lock.
try one of the new clips , even tho they look different , as the old one is apparently a bad design or broke
Mar 23, 2017 | 2000 Mercury Mountaineer
Removing clutch hydrualic line from trani., in order to replace
hi there that little clip holds the line lock in place make shure you wipe off the hose connection with a clean rag as you dnt want any dirt in line good work should go fine assemble as it was and bleed hydraulics bye for now
Jul 07, 2008 | 1992 Ford Explorer
Maytag Neptune top loader error code
I have had this problem 3 times. My washer just started this again last night. UNPLUG MACHINE FIRST!! If you are standing in front of your mashine, the top lifts up (you can use a butter knife or screwdriver to push in the clips, they are about 2 inches in from the corner). There will be a white lock control on the left hand side, just under the lid by the bleach dispenser. It has a little silver bolt/screw holding it on. Remove this, but watch out, the bumper will fall off from the other side. Unplug the wires from the lock mechanism. It just pulls out. There are little locks that hold the lock mechanism closed. They will probably break, mine did! Open the mechanism. There is a little glass tube with a black wire soldered to one end and a red wire on the other. The wire is so little, it rusts off quickly. That's exactly what I found. You can resolder this and then tape the mechanism back together. This is very easy. I already have a repair scheduled (Extended warranty), but everytime I have this piece of s____ machine fixed, it costs me the price of a new machine that actually works in laundry mat fees for my family of 7. If this will hold me the 2 months it takes till then, what the heck!
Oct 01, 2007 | Washing Machines
Smith Corona Wordsmith 100 Typewriter Logo
132 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
