Question about Canon MV800 Mini DV Digital Camcorder
I can't insert any tape into the camcorder, cause it goes out
When I insert the tape, it goes out. I tried with many differents tapes, but all of these go out; so I can't do nothing: I can't record a new tape, I can't see the old tapes, I can't bring the moovies in my computer.. Thank you
SOURCE: Canon zr300 ejects tapes
I just tried the "Fonzie" fix in my ZR300 and my camera now works - cassette compartment closes all the way now with the tape inserted. It just took one "hit" to fix the prolem. I was surprised. But ericemartin's solution is worth a try.
Posted on May 28, 2008
I cannot believe this but it does work
Posted on Sep 04, 2008
SOURCE: Tape problem, Elura 100
I took mine apart and there's a little switch on the backside of the camera that controls the opening of the cassette mechanism. It is meant to be tripped by the opening of the side of the cassette case and then triggers the ejection of the tape. The switch is probably just stuck. Taking this apart isn't too difficult - I think about 4 screws.
Posted on Nov 28, 2008
SOURCE: Cannot insert tape into canon MV800. Always ejects
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
Posted on Dec 18, 2008
  • 154 Answers
SOURCE: canon es900 8mm camcorder won't allow tape insertion
Canon ES series camcorder was designed with 1000 hour capacitors on the processor boards. When the time comes these capaictors loose value and create problems for the main computer to communicate with other mechanical system in the camcorder. We were able to service well 7 years ago but the life of these component has aged too much to make it good anymore. I wish I have a better news for you but the success repair on 'ES model is very slim and if repaired, the labor charge may run many times over of the value of this camcorder. You can probably obtain a newer used camcorder at decent price and get all you tapes into DVD quick. Good luck -James
Posted on Mar 27, 2009
  • 5 Answers
SOURCE: Canon ZR850 won't accept tape
ok what you do is take the batery pack out and hit the camera there/
if it dont work try again
Posted on Apr 21, 2010
0 characters
1 Points
I have a sony Handycam videoHi8 camcorder, my problem is that it
Try using different tape or a new tape in the Camcorder.
Clean the video heads using the Sony V8-25CLD cleaning cassette.
You may also try pressing and holding the Reset button for 30 seconds to reset all the settings in the unit to the factory defaults.
Good luck!!!!!!!!! !!!!!!!!!
Sep 19, 2009 | Sony Video Cameras
Eats tapes!!
Try using a DV tape cleaner to clean the tape heads first and see if that makes a difference.
Sep 26, 2008 | Canon ZR10 Mini DV Digital Camcorder
Inserting tape into camcorder
bent guide pins, dried out grease, belts got old although you say new, some object stuck inside jamming gears.... the list goes on.
Mar 22, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
When trying to record
You need to check the small switch on the tape and switch it the other way.
Feb 26, 2008 | JVC GR-D244 DV Digital Camcorder
Camera will not accept mini-dv tape anymore
Is sounds like something got on the drum/video head ,that is sticky causing the drum not to spin when you put a tape in. You say that putting a tape cleaner in helped, and sometimes they will help ,but tape cleaner are not as good as having it cleaned by someone like me , a qualified Technician. or take it to someone closer. Larry
Dec 01, 2007 | Sony Handycam DCR-TRV480 Digital Camcorder
Remove tape error message
  1. Condensation is detected – If condensation is detected by the camcorder, the “Remove the Cassette” warning may occur.
  2. Component failure – If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder.
  3. Sand or grit damage – The camcorder’s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate.
  4. Impact damage – If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur.
  5. Liquid damage – If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation.
  6. Improper videotape insertion – If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual.
  7. Damaged or defective tape – If a tape becomes damaged, please discontinue its use.
Operational Recovery Steps
Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps:
  1. Eject the videotape
    Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2.
  2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry.
Nov 19, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel
Feb 28, 2007 | Sony CCD-TRV228E Camcorder
Tapes won't play
This is an indication that both data heads are dirty. In a digital camcorder both heads need to be operating correctly to obtain a full picture. Insert a new cleaning tape and run it for only 10 seconds or less, this should clear up the problem. Avoid using the tape that caused the problem. Do not use the cleaning tape for regular maintenance, this will damage the drum surface. Good luck to you! Joe Weibel Custom Electronics (
Feb 14, 2007 | JVC GR-D250 Mini DV Digital Camcorder
"Tape Not Inserted" on Panasonic PV-DV203 palmcorder
hai, If you are service engineer you can do this problem, Please, check the cassette IN sensing Switch. The place of the Switch is right side of the mechanism, Clean S/w with IPA solution & check. It will be ok or other wise you have replace s/w or mechanism.
Nov 08, 2006 | Panasonic Palmcorder PV-DV203 Mini DV...
Canon MV800 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
